Thread: Vacuum Breaker not Re-installed after Pool Repairs
    Jul 2012
    Basking Ridge, NJ
    46
    Hi again all,
    Before the pool was opened this season, we had several major repairs done to our pool w/ attached spa. There used to be a vacuum breaker installed on both the pool drain and the spa drain. However, when they 'finished' the repairs they only re-installed the pool vacuum breakers and simply put a PVC cap on where the spa vacuum breaker was. It's kind of scary that I'm just now thinking of this, but would that be the reason the spa always looks half empty before the pump starts in the morning?
    The attached picture is the style that both breakers are.
    Thanks for any and all help,
    - Patrick
    28,000 Gal Pool w/ Attached raised Spa, White Plaster Finish, D.E. Filter - FNSP 60 sq. ft., Whisperflo Pump, Nature 2 Element (Housing Only Now Devoid of Cart.), Hayward CL200 In-Line Automatic Pool Chemical Feeder, RayPak Gas-fired Heater, Polaris 380, Zodiac 1.5-HP 240-Volt Polaris QT Spa Blower
    22,542
    Re: Vacuum Breaker not Re-installed after Pool Repairs
    The missing vacuum breaker isn't the reason the spa is draining. That would be caused by a leaking valve or check valve.
    You say major repairs. Did they change the main drains to be VGB compliant? If they did then you don't need the vacuum breakers. However, it's not a bad idea to have them anyway.
