Results 1 to 8 of 8
Thread: Lil Shark for Intex 2000GPH Krystal Clear pump?
    Sep 2012
    Australia
    63
    Hi, does anyone know if the Pentair Lil Shark cleaner will work with the Intex 2000gph filter pump ("System flow rate of 1,650 GPH; pump flow rate of 2,000 GPH"), and if they are any good?
    http://www.amazon.com/Intex-54611EG-Kry ... stal+clear
    http://www.amazon.com/Kreepy-Krauly-Sha ... m_sbs_hi_3
    I have read the online manual on the Pentair website, but it doesn't mention the minimum pump size required.
    Mar 2012
    Amarillo, Texas
    341
    Re: Lil Shark for Intex 2000GPH Krystal Clear pump?
    My Lil Shark wouldn't work with the stock intex filter. I have a 1 1/2 hp pump and it moves quite rapidly.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Sep 2012
    Australia
    63
    Quote Originally Posted by mpacheco72
    Which Intex pump did you have as there are quite a few different sizes?
    Mar 2012
    Amarillo, Texas
    341
    To be honest I don't even remember. My friend had the small Intex sand filter and couldn't get it to run off of his also.
    18'x48" AG
    Hard Plumbed
    Sep 2012
    Australia
    63
    Did it look like this by any chance?
    [attachment=0:2sqncc79]51IzjNhAj6L._SS500_.jpg[/attachment:2sqncc79]
    Mar 2012
    Amarillo, Texas
    341
    I believe I had the 1500. No SWCG. It wouldn't even budge with that. If you lived around here I'd let you try it out before you bought it. He ended up buying two vacs and neither worked with his Intex Sand Filter/Pump either.
    18'x48" AG
    Hard Plumbed
    Sep 2012
    Australia
    63
    Hmm.
    There is a reviewer on Amazon who has it working with the 2650gph Intex sand filter pump.
    But didn't work with your friend's smaller sand pump at 1650gph and your pump possibly at 1500gph, so I'm not sure if it will work
    with my 2000gph.
    How well do you find it works as a cleaner?
    I suspect it would work better on a round pool rather than my rectangular.
    Thanks
    Mar 2012
    Amarillo, Texas
    341
    I think it works a lot better than hand vacuuming. I have problems with it getting stuck in the same area, but I just go out and "adjust" it every once in a while. I was going to buy a robot this summer at the end of the season, but I haven't gotten around to it. We are looking at a larger pool for next summer and I'll be curious to see how well it does with that.
    18'x48" AG
    Hard Plumbed
