Thread: New Pool Owner - How to properly close my pool
    Ok, so I am a relatively new pool owner.....last year I paid someone to close my pool at the cost of $300. I'd like to do it myself this year
    I purchased a pool closing kit, so I have all the chemicals I need.....I just don't know the process.
    I know water needs to be removed from the lines, I was told I can do this with a wet dry vac...but im honestly not sure which lines need to be blown out.
    Here is my set up:
    The pool
    The Filter:
    First step is to backwash and then remove the filter element and plug all the lines in the pool and skimmers.....beyond that, I need some help
    I do have an elephant cover , so I know that's the last step.
    Go easy on me, I am a newbie to this and just learning. Thanks in advance
    7,200 Gal, Cartridge, IG, Fiberglass, PAL-2000 2 Lights System, Hayward Universal H-Series Gas Heater, Oskar
    22,549
    Re: New Pool Owner - How to properly close my pool
    Where are you located? It makes a difference in the amount of work required.
    You almost have it right.
    Backwashing is fine and I assume that's a DE filter so removing the grids and cleaning them is good.
    You need to need to raise the FC to shock level for your CYA and then lower the water level and then blow the lines and plug them.
    I am located in Massachusetts, it is a DE filter
    Interesting about draining the water, I remember having to take the plugs out and they were definitly under water.....is that from rain water getting in or did the pool company fill it back up after?
    where do i blow out the lines from? I am assuming inside the skimmer basket attached to the filter, then turn the valve to get the other return lines?
    22,549
    Since you don't have any unions it's a little harder. You could blow it from the pool to the pad but that's kind of a pain. Clean the filter then blow from the skimmer all the way through each return.
