Results 1 to 7 of 7
Thread: wiring 4 wire 220v pump
    I am trying to wire a 220v pump and heater. There are a red, black and a green wire coming from pump and heater. I am being told I need a white neutral but no one can tell me where it gets hooked up at. Anyone have any idea?
    Thanks
    12' x 24' IGP, 7700 gal, Jandy Aqualink PDA, Jandy LRZ 2500,000, Jandy CL 340 filter, 1hp Jandy Stealth pump, Jandy Aquapure SWG.
    38,463
    Re: wiring 4 wire 220v pump
    Hooking up 220V equipment does not have a common (white) wire. Only 2 hots and the ground ... I would not trust whoever is currently giving you electrical advice.
    Are you just trying to hook the pump and heater up? Or are you trying to put in a subpanel?
    4knights's Avatar
    NE Kansas
    419
    Jason's right,
    I'm prepping to do the same thing and luckily I have a friend that is an electrician. The black and red are your hots(120volt each) the green is ground. That's straight from the load center breaker to the pump wiring. The 4 wire setup is from main panel to subpanel- red & black are hot, green is ground white is Neutral to panel. You should have a bonding wire that runs from your subpanel to the side of your pump as well as the ground wire.
    Don't know about heaters as I am not getting one.
    http://www.inyopools.com/guide_wiring_w ... _dual.aspx
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jun 2012
    western NY
    1,562
    If the circuit only contains 220 volt loads then no neutral is required. If there is any 110 volt loads involved such as control panels etc then a neutral is needed. You mentioned you are hooking up a pump and heater. Are you running these out of a sub panel or are they on two different circuits from the main panel?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    I ran 4 wires to sub panel ( red, black, white and ground). From sub panel I ran red, black and ground to pump and heater on separate breakers. There is also a light and a automation system on their own breakers using 110v coming out of sub panel.
    Jun 2012
    western NY
    1,562
    Is the heater a 220 volt unit?
    Yes, the heater is 220v.
