Results 1 to 10 of 10
Thread: Raypak 206A Propane Heater
    Aug 2010
    Sarasota, FL
    22
    I have a Raypak 206A heater which is just over a year old and no power.
    Fired up the heater yesterday to bring the pool temp up a few degrees and I noticed the I wasn't getting any heated water. I went out to the unit and the display was blank like it had no power. I removed the cover and and made sure the connections(AC) to the unit were okay. Took a meter to make sure I had AC power and I was a little confused on what I was seeing didn't appear to be correct but I was rushing because it was beginning to rain. I may have had the wrong value selected on the meter. In addition I checked the power switch itself and it was good.
    What I didn't do is check the other side of the transformer to verify 24VAC.
    Has anyone else run into this problem. I picked Raypak for its reliability. If the board is toast I'm going to be upset.
    20k gal pool/spa, marc, 2 hp pentair whisperflo, Pentair clean & clear filter, Raypack Reheem 266 heater. Taylor K2005 test kit.
    Jun 2012
    western NY
    1,560
    Re: Raypak 206A Propane Heater
    Is this a standing pilot unit or is it an electronic ignition?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    A year old huh? Is the unit green in color or the new paint scheme?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Qwaxalot's Avatar
    Jun 2012
    439
    Raypak has been having a problem with excessive board failure recently. You should be able to get a replacement board under warranty (do verify that the transformer is supplying 24 volts AC).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by Qwaxalot
    It depends on when the unit was manufactured. Not all units are covered.
    Paul
    Jun 2012
    western NY
    1,560
    Comment removed by request.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    danpik, I have yet to find or see a universal board for a pool heater. Maybe on a furnace or AC unit you can find that but not on pool heaters. I've been working specifically on pool heaters for over two years and have a cousin and a friend that do the same thing for over 10 years each and they have never seen a universal board either for a pool heater.
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    1. Check the secondary of the x-former (as you thought), for 24v
    2. Raypak is NOT having a problem with the boards, it is the LCD screen that is the problem, which Raypak is covering.
    3. Raypaks' standing pilot heaters do not have a transformer(IID). Come on guys! If you don't know, say so, or don't comment. It makes you look like you don't know Raypaks.
    4. If you replace any part that is not from Raypak, you void the warranty(this one is less than a year).
    Factory Warranty Station for:
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Just remember that even though a heater might have been installed in the last 12 months it could still be older than that. I routinely have to fight with suppliers to get models that were manufactured in the current year or within the last 3 months of the previous year. As example, I went to pick up a unit last month and it was manufactured in Jan of 2011! I refused to take it and made them give me a newer unit. Yes the unit was new but it had been sitting in a warehouse for that long. Stock rotation can be an issue with some suppliers. Yes the manufacturer will cover it for warranty issue for one year from the date of the installation.
    Pool Clown is correct about the display issues and not the board. The question still remains on if this is the newer model that the OP has or an older one, old color scheme.
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Rapak will warranty heaters over a year(on the shelf) as long as you have documentation of the install date (invoice/ receipt) of less than 1 year.
    If you have the invoice from a supplier, they (the supplier), shouldn't fight you on it.
