Thread: Pool closing--to drain or not to drain below return???
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    First time closer--
    24x54 sharkline agp owner--first year
    I hear people say to drain several inches below the return, while others claim to cover the skimmer opening with some sort of water tight sealer(plate), and then plug return eyeball so as to keep there water level pretty much same level as needed to swim.
    What is best way to close? It would be nice to keep as much water as possible so as not to have to top off in spring, but are you gambling with ice damage leaving the pool full over winter??
    Also--best cover for a plastic top rail pool--very very windy at our place, and what is purpose of an inflated pillow under winter cover--expansion control for freezing water??//
    Can you tell I'm new at this????
    24x54 Sharkline Matrix
    Hayward 1 hp Powermax single speed pump
    Hayward ec50ac DE filter
    22,553
    Re: Pool closing--to drain or not to drain below return???
    It's hard to give winterizing advice without knowing where you're located.
    If you were in my area you don't have to worry about all that fancy freeze protection. Plug the skimmer and return, drain the plumbing and equipment and walk off. Fire it back up next year and you're good.
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    South Central Pennsylvania
    We do get a pretty decent cold winter here most of the time. There are years where we get hammered, years where it's light. All in all you have to be prepared for a bad one. Below zero is not out of the ordinary.
    22,553
    In that case you should drain below the return so the ice won't damage it or the skimmer.
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    better safe than sorry I guess. thanks
