Thread: old polaris
    Feb 2008
    Ohio
    156
    old polaris
    we have a old polaris (3 wheeled) that is working but, I have a question about the backup valve....it doesn't seem to have one???
    I guessing this must be a polaris 180 but, not positive (I don't see a number) its pretty old but, has updated parts (wheels, float, etc) so does anyone know if a old polaris had a backup valve?
    it seems to do okay cleaning (it helps me out) and everything else seems to be working on it.
    thanks,
    Chris
    30-40yr old prehistoric IG gunite 20 X 40 approx 30000gals
    now with new cool blue Diamond Brite and blue waterline tile (looking good for 40yr old pool)
    new Hayward 244T sand filter, 3/4 Hayward pump, Jandy heat pump
    pool skim (love it)
    Apr 2008
    Central Texas
    326
    I have a 280, so I'm not sure what was standard on the 180. However, the backup valve is only used to get the Polaris out of a corner or someplace that it might get stuck. If yours doesn't get stuck in one spot while cleaning, then you don't need the valve anyway.
    Every 3 minutes or so the valve shuts off the water flow to the cleaner and diverts it through the backup valve. This lifts the Polaris and moves it to a different spot in the pool. The valve then switches back to cleaner mode and the Polaris takes off once again.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Apr 2008
    Central Texas
    326
    Oh yeah, if it did have a valve at one time, the previous owners may have deleted it if it failed, after they discovered what it costs. A new one runs $70 from the local pool store. I had to replace mine last year and found a much better price on eBay.
    Polaris 280
    Feb 2008
    Ohio
    156
    great info, thanks!
    Yes, I think you are correct about previous owners not replacing it...we also went by Leslie's today and they wanted $77 for it but, luckily I also looked on Ebay and saw way better prices.
    it seems okay without it for now, we don't have any obstacles or sharp corners...so maybe we will see how she runs for awhile without it. Its been doing great picking up all these crazy tree seed pods that are everywhere...now I know why know one else has opened their pools (there are tons of trees around)
    thanks,
    chris
    pool skim (love it)
    JoshU's Avatar
    New Orleans, LA
    543
    The price of $77 is a bit high.
    An easy way to tell which is which...
    The 180 has 1 jet in the throat of the cleaner.
    The 280 has 2 jets in the throat of the cleaner.
    The 380 has 3 jets in the throat of the cleaner.
    - Josh
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
