Thread: EDITED: Need help - how to handle this AGP drain setup
    Tecumseh, MI
    53
    All my my homes' gutters/eaves troughs drain into the ground (and I assume sewer system...only lived here 2 months). My 15x30 AGP oval also has a drain pipe running off the skimmer that leads into the ground. But opening the valve doesn't allow any water to drain through it...none, though it does seem to act as a vent pipe - it seems really strange to me that it would vent air for other pipes, but water won't drain through it...something about plumbing that I apparently don't understand.
    (I'm sorry, i can't figure out how to post the pics I took for this, they are each 3.67MB, so I have no idea how you guys do it with a 25K limit...if I"m overlooking something, sorry) My skimmer exit line has 2 valves on it. The first valve stops water from getting to the "T-branch", where the skimmer line enters and then branches to either the ground or the filter system. The 2nd valve leads from the T-branch to the ground (I assumed it was to prevent the water from draining into the ground, but I guess it's just a vent pipe?
    Here is my best attempt to make a visual of the system
    the # represents PVC pipe water line:
    valve
    ################> line to filter
    valve
    continues to ground
    Questions:
    1) I'm only using siphon to lower the water...I am NOT using the 2 floor drains that the pool also has. I do not know if they've ever been used. Do I need to do anything with those 2 floor drains?
    2) How should I handle the 2 valves that come off the skimmer? Should I leave them open and not bother to blow the lines or use antifreeze? Should I blow them & close them? Should I antifreeze them and close them? Other?
    3) Is that second valve some how related to the 2 floor drains??? IF so, how??
    4) If blowing or antifreeze is involved, how much of each? I know shopvacs and recommended for blowing (how about a leaf blower?), not knowing how long the lines are, I'm not sure how to handle antifreeze if you guys advise it.
    5) What is a GIZMO and do I need one?
    Thanks for the help! And I'd gladly post pics to help if you can tell me how.
    ~12,500 sqft above ground, 95 sq ft Sta-Rite Posi-Clear Cartridge filter, installed by previous owner in 2010?, Proud TF100 user!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: EDITED: Need help - how to handle this AGP drain setup
    Quote Originally Posted by Hiesman84
    valve
    valve
    continues to ground
    Questions:
    Gizmo is the thing that allows the skimmer and main drain to operate independantly via the skimmer suction line to the filter/pump. They are also called spacehips.
    Pictures: how-to-add-pictures-to-a-post-full-guide-with-screenshots-t45050.html?hilit=post pictures
    38,251
    They are called something like float diverters to allow you to adjust skimmer/floor suction (either a spaceship or twinkie).
    I thought gizmos were used for winterizing the skimmer?
    Jun 2012
    Mint Hill, NC
    2,589
    Heck now I'm confused... Mine has separate lines so I haven't needed to learn this!
    -sent with Tapatalk 2
