Thread: How long do I have to wait after adding CH and TA increasers
    Jul 2012
    Bel Air, MD
    52
    Hello all,
    I am working with a 300 gallon hot tub with brand new water. I tested CH and found it to be 70ppm. I also tested TA and found it to be 70ppm. I have added enough CH increaser to bring the total to ~140ppm and have added enough Alkalinity increaser to bring it to 80ppm. How long should I wait until testing again?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: How long do I have to wait after adding CH and TA increa
    If it's running, half an hour should be more than sufficient. Hot tubs and spas tend to mix the water quite vigorously.
