Thread: What is proper winter care/storage for my solar cover?
    Tecumseh, MI
    53
    Standard white bubble-wrap type solar cover, 15x30 oval. What do I need to do with this thing over the winter?
    - Mop/brush the top side with a 10:1 water/bleach mix?
    - Roll it up? Fold it up? How tight it ok? Does it need to be as "open" as practically possible to minimize moisture getting trapped inside and mildew build-up?
    - Inside (garage or basement) vs outside (shed) make a difference?
    ~12,500 sqft above ground, 95 sq ft Sta-Rite Posi-Clear Cartridge filter, installed by previous owner in 2010?, Proud TF100 user!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: What is proper winter care/storage for my solar cover?
    I let mine dry real good on the driveway and blow it off with my backpack blower. It then gets rolled up and placed in a contractor sized trash bag and just losely tie the top. I store it in the garage attic space, but shed, etc would be just fine too...as long as there are no mice around
    Quote Originally Posted by dmanb2b
    This year I'm planning to try fitting my cover in to a large rubbermade tub. I've always debated about cutting it, maybe now is the time to split it up. Our shed seems to attract mice from the back of our property. Haven't seen many of them this summer, but they're around, my winter cover now needs to be replaced.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    linda1's Avatar
    Mar 2010
    Western Pa.
    296
    I hosed mine off and then let it dry and folded it section and a time making sure it was completely dry before folding over another section. I then put it in the large plastic bag it was shipped in and taped all open edges. I put it in our barn for the winter.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
