Thread: Can fire ash cause CL demand?
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Will visible black ash that has fallen from the sky, from a large nearby forest fire and collected in the pool cause a CL demand?
    It is so fine you just touch it and it goes POOF!
    On dry land that is.
    Here's the fire just for grins.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Can fire ash cause CL demand?
    I believe so. One year when we had fires near us, I had to raise my SWG output. I had to add CYA more often too so that could have been part of the cause.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    According to this paper, in wood ash the major elements are calcium, potassium and magnesium. Oxygen and carbon are present, and for low temperature heating (600C) the result is calcium carbonate and potassium calcium carbonate while in high temperature heating (1300C) calcium oxide and magnesium oxide were the main compounds. Ash is alkaline so will raise the pH. I'm not sure where the chlorine demand is coming from unless there is unburned wood organics in some of the ash.
    mas985's Avatar
    Pleasanton, CA
    11,743
    I wasn't suggesting that the ash itself causes a chlorine rise rather a mechanism to bring more organics into the pool. More like a vehicle for transport. But that is just speculation. This may not be unlike rain which can also force organics out of the air into the water and why pools can sometimes get an algae bloom right after a rain.
    Mark
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    The question is, will it provide enough organics to potentially cause an OCLT to fail at std shock levels?
    I'll take some photos of the stuff on the ring of the pool tomorrow. You can literally stand outside and watch it fall from the sky, my filter has charcoal spots in it and the skimmer sock of sorts that I'm using turns black with ash, even collecting in small clumps, about 1/8tsp in the bottom.
    I almost feel that until this fire passes, I'm never going to know if I can stop shocking or not. GRRR
