Thread: Spa starts to drain when switched to SPA mode
    We are having trouble getting our spa to operate today. Everything seems to be working in POOL mode but when switched to SPA mode, the jets are not very forceful and the spa is draining. We have Jandy automated valves which appear to be moving appropriately (one on top moves in opposite direction of the other one). Any help is appreciated.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Spa starts to drain when switched to SPA mode
    Are your valves labeled? Has anyone done any work on your system lately? Maybe one automated valve isn't operating at all. Make sure that all valves rotate when you put the system into the various modes. Stand by the valves and watch as you test and make note of what is turning and what might not be. The main drain valve for the spa is open when it should be closed.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by prillman
    It seems like Jandy valve that controls the return side is not closing the pool returns completely. They can get out of adjustment, jammed or the diverter can leak.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
