Results 1 to 8 of 8
Thread: Is sodium hydroxide in bleach normal/ok to use in pool?
    Melbourne, Australia
    74
    Hi guys.
    Found some bleach at ALDI supermarket - extremely cheap but only 4% strength sodium hypochlorite. that's ok...
    But It also says in the active ingredients it has sodium hydroxide 9%.
    Is the sodium hydroxide OK to use in pool?
    I am shocking at the moment and can't get the better 13% liquid chlorine...
    13,000 gallon; sand filter; inground; fibreglass; pump not sure yet (need to check); Installed over 12 months ago.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Is sodium hydroxide in bleach normal/ok to use in pool?
    Cheap bleaches such as these are not as good as 6% Wall-Mart or 16% Supply but do the job ok, the additional Sodium Hydroxide or "lye" will have a slightly pH+ effect, but not much really. You don't have any real concerns about using it.
    Regards
    Stu
    Stuart Murray
    Scotland UK
    UK NPPOC
    74
    Thanks stu...
    It's sunday morning here and I am shocking and can't pick up some 13% till tomorrow.
    I'll just get some cheap stuff to keep the shock process happening...
    Cheers.
    Mar 2007
    San Rafael, CA USA
    12,082
    Are you sure it says 9% sodium hydroxide and not 0.9% (which is still high -- good chlorinating liquid has 0.25% and Clorox bleach is < 0.1%)? If it's truly that high DO NOT USE IT. It will significantly raise the pH and require you to add a lot of acid. If it were truly 9% sodium hydroxide, then it would require about 30 fluid ounces (almost a quart) of full-strength Muriatic Acid (31.45% Hydrochloric Acid) for every gallon of bleach that you use!
    Jul 2012
    296
    I don't think the peroxide level quoted is correct, I've used Aldi bleach here in the UK many a time for poolside cleaning, washing it into the pool afterwards without any change in pH.
    Stuart Murray
    Scotland UK
    UK NPPOC
    74
    Oops sorry I got it wrong it says 9g / litre which is 0.9%
    I will use it this once until I get some liquid chlorine tomorrow.
    Aug 2014
    VA Beach VA
    4
    Where do you get the 16% bleach? I normally use the 8.25% from Kroger or WalMart, but was looking at the bleach from Home Depot, which does have <1% Soldium Hydroxide (which is how I found this thread.
    I finally learned to NOT use Dollar Tree Bleach, after way too many $$ spent on basically water
    27,000 gallons plaster in ground with Hayward Sand Filter. The pool is older but was repainted this year.
    Jun 2017
    New Orleans, LA
    89
    Quote Originally Posted by bzbmom View Post
    The OP is in Australia. I'd be interested to know if any U.S. states allow retail sale of 16% bleach.
    Some states allow up to 12.5%, some (like mine) cap it at 10%. There are other states still of which I have no idea.
    Intex 16' x 8' x 42" Prism Frame AGP, vinyl liner, 3,300 gal, opened 5/28/2017. Intex Krystal Clear Model 637R Filter Pump. Cartridge filter (Size A). 6-way HTH testing kit.
