Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Removing Dilapidated Stickers from Fiberglass
    Pittsburgh, PA
    37
    How can we remove these dilapidated stickers from our inground pool without harming the fiberglass rim? It seems like what remains of the stickers is sun baked into the fiberglass. We've tried Goo Gone, 409, etc to no luck.
    TFP Forum and the BBB Method Changed My Life!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Removing Dilapidated Stickers from Fiberglass
    magic clean eraser may work, but it also may dull the surface. Try a test patch first.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Get new ones slightly larger and slap them on over the old ones!
    - Sent using Tapatalk
    38,475
    Quote Originally Posted by UnderWaterVanya
    That was my first thought too.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2012
    Mint Hill, NC
    2,589
    Typically I would not recommend a sticker over a sticker for fear the old one would come off. But in this case the sticker may be around after the pool turns to dust!
    Pittsburgh, PA
    37
    We want to go stickerless. The company that did our last liner replacement put them on without asking. We were not happy about it.
    Karmann's Avatar
    Apr 2012
    DFW Texas (Midlothian)
    123
    have you tried using a really sharp razor blade to gently scrap it off?
    Martin,
    Midlothian, TX
    Pool built in August 2012, 17.2k gallons, IG Gunite/PebbleTec (Midnight Blue), 1k sq ft Washed Aggregate decking, Jandy Stealth 2HP Pump shared with Spa, Aqua-Pure Salt-Gen, Jandy 1.5hp wtr feat pump, Jandy CV580 Cart Filter, Jandy AE3000TR Heat Pump w Chiller, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Jandy Pool (2) and Spa (1) Multi LEDs, 2 Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl 3' sheer descents and spa spillway
    Click Here For My Pool Build Thread
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Acetone/fingernail polish remover?
    Car polish? Maybe polishing compound/rubbing compound first, then polish/wax to shine it up.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Nov 2010
    Calera, Al
    271
    Use a hair dryer to warm the sticker and the sticky will start to loosen. Work from one corner to the far corner peeling it back and warming.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Pittsburgh, PA
    37
    Quote Originally Posted by X-PertPool
    We bought a Magic Clean Eraser and tried it. It didn't do a thing for the stickers but it did clean up the surrounding fiberglass nicely.
    Quote Originally Posted by Karmann
    We've been avoiding sharp and/or abrasive methods because we're afraid of damaging the fiberglass.
    Quote Originally Posted by CUTiger78
    Is acetone safe for fiberglass?
    Car polish sounds like a reasonably safe idea. I thought about trying buffing compound (aka "tripoli" aka "rouge") but I was worried about getting a bunch of it in the pool. Every time I use that stuff on my buffing wheel it gets everywhere. I'm covered with it and so is the shop.
    Quote Originally Posted by ROB N
    Good advice for stickers that are still stickers. My "stickers" are rock hard. There's no stickiness left in the adhesive. It's as if the adhesive has hardened into an epoxy or something. I've tried to pull up small pieces on the corners with my fingernail but I'm not able to lift any part of the sticker from the fiberglass. The "stickers" are really hardened on there. I've never seen anything like it in my life.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by kristof
    Make a "clean room" type cover with plastic drop cloths and holes for your arms. Use some type of wire or maybe spring fiberglass tent pole to hold the bubble open.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I don't think a little buffing compound in the pool will hurt anything. Careful with electricity around the water though!!
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Melt In The Sun
    AMEN! This is where an 18v buffer would be helpful...
    Qwaxalot's Avatar
    Jun 2012
    439
    ROB N has it right, however a hair dryer might not get hot enough. A heat gun and a razor blade (to start it lifting), followed up with "goof off" then polish. It will work.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    SW Georgia
    300
    What about mineral spirts/paint thinner?
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I second the heat gun. I've never seen an adhesive, however old, that could not be heated to removal.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Pittsburgh, PA
    37
    I'll try the heat method next. I have a hot air station that I use for electronics. The temperature is adjustable from 100F up to about 800F. Does anyone know the maximum safe temperature for fiberglass?
    Oct 2009
    3,899
    Good question...the glass itself would be fine, but I bet you can start burning the gelcoat somewhere in the 300 degree range, or even lower. Perhaps the manufacturer of your pool would know.
    Karmann's Avatar
    Apr 2012
    123
    I REALLY think a razor blade and some WD-40 to soften the adhesive would be less risk at damaging the surface than the heat gun would.
    I've used a razor blade on cherry wood furniture before to get up stickers without a single scratch, just go at it with the right angle and you're good to go.
    Maybe you can try something like this stuff below, it looks like it would do the job pretty well also.
    https://www.youtube.com/watch?v=jILw0WcZxMU
    Martin,
    Midlothian, TX
  20. Back To Top    #20
    X-PertPool's Avatar
    Exeter, PA
    1,385
    BE VERY CAREFUL WITH ACETONE OR PAINT THINNER. The print on your liner is only ink, if you get that stuff on vinyl the print will come off as if it was printed with a dry erase marker. Acetone is what is used in special circumstances where the print is damaged on the vinyl and you use the acetone to transfer the print from once piece of the vinyl to the damaged area like a stamp.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
