In that case, 50ppm CYA may not be high enough to have the FC last a week.
What does the water look like? If it is already green, then clearing it at the high CYA levels is more tricky. There are some pretty big differences between owner maintained and serviced pools with the way things are done.
For example, an owner doing the shock process keeps the FC at shock level hourly and in doing so never raises the FC high enough to cause any damage. A service will come out and drop a nuclear amount of chlorine in the pool all at once which "might" be enough to kill everything at once, but it also may be causing damage to the pool and equipment.
Just want you to realize that the methods taught here may not be directly applicable to your business.
