Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: CYA above 140
    CYA above 140
    Hello
    Just starting out in the pool business and I have a customer with CYA at a hi level. I took my reading with the Taylor k2006 and with the colorQ pro 7 both read Hi. My customer has a 19000 Gallon pool so I drained 6500 Gallons the other day and refilled it. I ran the filter the normal 8 hrs and went back to take a reading. The CYA level is still reading HI. So my question is will draining another 6500 Gallons of water solve this problem or will I be wasting more time? Also I'm reading to many different way to add acid to a pool to lower Alkalinity could you please tell me the proper way to pour acid in the pool for Alkalinity...Thanks
    14,000 Gal. In-Ground Plaster Salt Water Pool
    Pentair IntelliFlo VS Pump
    Cartridge Filter
    Aqua Rite Chlorine Generator w/ T-Cell-3
    6-panel Solar Heater
    Purex Triton MiniMax Plus 400 Gas Heater
    Built 1999
    38,242
    Re: CYA above 140
    Welcome to TFP !
    You need to be more specific with the CYA level. What reading are you getting with the K2006? If it is over 100ppm, try diluting the pool water 50/50 with tap water and redoing the test, doubling the reading. You can then determine the % of water replacement required to let it to a certain level.
    For the TA reduction, there is an article in Pool School that describes the process. Basically using acids to lower pH and TA and then aerating to raise the pH back up so you can add more acid ... and repeat.
    The slug method for TA reduction is a myth and can damage the pool. Just pour the acid slowly in front of a return.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: CYA above 140
    Use a dilution test using 1 part pool water to 1 part fresh (2 parts, or 3 parts etc etc) water to get a true CYA reading, there's no point in saying if I drain x, as you really need to know albeit roughly what the current CYA level actually is. Draining 50% of the pool water will lower the CYA level by that amount and so on.
    As for your question regarding adding acid to a pool we generally recommend dissolving it in a bucket before adding it in front of the returns (or water inlets) to the pool.
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    Re: CYA above 140
    Ok thanks for the tip! Next time I go I will do the 50% on the cya test. The reason I asked about the acid is bc the guy that tought me said to pour the acid in a circle in the deep end. Now I know that doesn't matter.
    Cartridge Filter
    Built 1999
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CYA above 140
    Read how to Lower Total Alkalinity. The key to lowering it a lot is to lower the overall pool pH to around 7.0 and aerate the water as much as possible and add acid to keep the pH low. The aeration at low pH drives carbon dioxide out of the pool water faster.
    Re: CYA above 140
    Ok I went back to my pool today 19000 gallons and after draining 6500 gallons my CYA at a 50/50 with tap water and pool water reads 100. So I guess we are talking a 200 CYA count. On that note does this mean I must drain at least 50% of the pool water or maybe 75% of the water? I just got this acct so it won't look bad on my part if I tell my customer he needs to drain more water.
    Cartridge Filter
    Built 1999
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: CYA above 140
    Quote Originally Posted by Keepinitclean
    If you hit 100 at 50/50 - try 1/3 pool water and 2/3rd's tap water and verify that you come in somewhere around 30-35. Multiply the result by 3 and see where you are. I'm afraid if you hit 100 with 50/50 it could be worse than 100 still. Absolute accuracy of the test is low (+/- 15ppm with undiluted samples), but better than guessing.
    38,242
    Re: CYA above 140
    That means you could be anything over 200ppm. I would say at least another 75% water change needs to be done. You could try the test again with 2/3 tap and 1/3 pool water and triple the reading, but you are loosing a lot of accuracy.
    UWV a little faster ... this time
    Jun 2012
    Mint Hill, NC
    2,589
    Re: CYA above 140
    Luck - just pure luck!
    Re: CYA above 140
    ok I'll head back there today and I'll use my colorQ pro 7 on this test.
    Cartridge Filter
    Built 1999
    38,242
    Re: CYA above 140
    How was the last test done? I am not sure how well the colorQ does on CYA (there are many reports in the forum about it). I would stick to the turbidity test that came with the K2006 (although I am guessing you are out of reagent since it comes with so little).
    You can get refills from tftestkits.net that are much larger.
    Re: CYA above 140
    I used the Taylor K2006
    Cartridge Filter
    Built 1999
    Re: CYA above 140
    Ok now with 1/3 pool water 2/3 tap water I get a reading of 50 ppm
    Cartridge Filter
    Built 1999
    Jun 2012
    Mint Hill, NC
    2,589
    Re: CYA above 140
    Then it is likely you are close to a CYA level of 150ppm.
    38,242
    Re: CYA above 140
    Taylor or colorQ? Mixing the results between the 2 test might get confusing.
    Taylor using 50/50 = 100*2 = 200ppm
    ? using 33/66 = 50 * 3 = 150ppm
    If it was Taylor, I think a 75% change is in order as you are likely between 150-200.
    Re: CYA above 140
    I used the Taylor on all the test for this pool
    Looks like I will be draining 75% of the pool. I don't see how a pool guy could have let it this high. Thanks for your help and the fast response time.
    Cartridge Filter
    Built 1999
    Jun 2012
    Mint Hill, NC
    2,589
    Re: CYA above 140
    Just for grins - might be worth taking ColorMote tests at 100% pool water, 50/50, and 1:2 ratio's to see how closely it parallels the CYA test in the Taylor kit.
    Re: CYA above 140
    Ok I might be going back tomorrow to drain the pool. I'll take it then and post it up...Thanks again!!
    Cartridge Filter
    Built 1999
    38,242
    Re: CYA above 140
    What exactly are your plans here? Just clear it once? Perform weekly service? Perform daily service?
    It is not uncommon for pool services to elevate the CYA to around 100ppm (or more) intentionally. This is because they only show up once a week (or sometimes every 2 weeks here). They come and jack the FC WAY high, and need the higher CYA level to protect it from the sun so it does not drop too much before they show up again in 7-14 days. They just hope the the FC stays high enough that the pool does not turn green before they come back (although it may have dropped lower that we would recommend). Then they shoot the FC way high again which kills off anything that may have started to grow and the hope they are good in 7-14 days again.
    This forum is more about daily maintenance for pool owners. If you are looking to do weekly service, you may need to adjust some of the recommendations found here.
  20. Back To Top    #20
    Re: CYA above 140
    I just took over two weeks ago for monthly service. I show up once a week.
    So having a high CYA level won't harm the pool in any way? and since I show up once a week I should leave it at that level?
    Cartridge Filter
    Built 1999
