Thread: sprung a leak
    May 2012
    Phenix City, AL
    34
    sprung a leak
    We have developed a leak in the line that comes out of the pump into the filter. I am not sure what to use to repair it. Currently there is a large amount of a silicone product that has I guess broken down and in allowing the leak. Do I use more silicone or is there a better product to use? I want to get this fixed this weekend as it has gone from a few small "drops" to an all out steady leak when we are running the system.
    16x32 Grecian IG vinyl pool Hayward filter swg 28000 gallons.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: sprung a leak
    It would help if you could be more specific about the leak - is it a threaded connection, glued connection, or the pipe itself? A picture would also help.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    May 2009
    Youngsville NC
    395
    Re: sprung a leak
    Usually it is best to just replace the pipe going from pump to filter in this type of situation. Find a spot where you can cut off the broken pipe, then glue in a barell connecter and new pipe (be sure to leave enough pipe for the glued sections to hold) and the same at the other end of the new pipe. At worst - start with the threaded connector coming out of the pump, and run all new to the threaded fitting on your filter. If you go this route, be sure to include a union fitting between the pump and filter.
    This is presuming you have PVC pipe like I do.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    May 2012
    Phenix City, AL
    34
    Re: sprung a leak
    It is PVC and not sure due to the silicone "caulking" that is on there if it is threaded or glued. I am thinking glued as the next connection above this area is glued.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: sprung a leak
    That is a threaded connection. You could try removing the old silicone caulk and re-caulk, but I doubt that would stop the leak. If there is a union downstream from the leak you can un-screw connection and re-apply teflon tape and calk to the threads. If there is no union cut the pipe far enough above the pump discharge nozzle to allow installation of a new thread X slip adapter and a union. Then glue everything back. That's not a big job and should take about 1/2 hour.
