Thread: oops to my lawn
    New Engalnd
    114
    oops to my lawn
    Hello
    So I have a big inground that i had to drain to below jets yadda yadda to close up. I shocked the pool and treated it before I closed it. I think the shock level was likely high, 8ish by the time i began draining. I drained it through a pump into a hose and onto my lawn. My lawn now a week or 2 later looks like light green in certain spots (where the water drained). Has anyone done this? Have I caused irreversable damage to my lawn? Will this be better next spring? Ugh..
    Matt
    Hayward Pump 3/4 HP - brand new
    sta rite sand filter - not sure of size, i will get back to this
    20 by 40 inground pool, vinyl liner, 8ft deep end
    2 skimmers and a main drain.
    1 jet in the deep end, 1 jet in the shallow end.
    Live in New England = about 3 months of pool usage.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: oops to my lawn
    If it does not go brown it should be fine. Otherwise you just may need to re-seed in the spring time.
    May 2011
    Orillia, ontario, canada
    50
    Re: oops to my lawn
    I found my lawn did not like the pool water at all. My lawn isn't in the best of shape though...
    It'll grow back
    Approx 74,000 liter inground vinyl pool 12x32, laser 225 sand filter, Hayward 2 speed pump + old pool heater.
    Mar 2012
    Amarillo, Texas
    341
    Re: oops to my lawn
    I backwash into my yard all the time. It doesn't seem to phase it in the least. In fact those areas are often greener than others.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: oops to my lawn
    It'll be fine
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
