Thread: Copper pipes and salt water sysems
    I'm converting my pool to salt water. Do I need to change the copper pipes to PVC?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,729
    Re: Copper pipes and salt water sysems
    All chlorine pools have salt in them so although it would likely be nice to switch to PVC not required IMO but do keep PH well balanced.
    Which pipes are copper?
    Support the site
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I run through 2 solar panels that have copper pipes in them. I've had no issues with the salt water and copper pipes.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    As described in this post, some gas heaters with copper heat exchangers have their warranty voided at high TDS levels needed for a saltwater chlorine generator. You shouldn't have any problems, but if your heater is new you should check your warranty.
