Thread: FC got high...safe to swim?
    Long story short...put solar cover on due to lower nighttime temps. Continued same maintenance routine. FC got high
    (but pool is immaculately clear).
    FC 18.5
    CC 0
    PH 7.4
    CH 150
    CYA 65-70
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: FC got high...safe to swim?
    You are well below shock level - swim away.
    That was what I was wondering...the pool calc says 19 is shock level, but the other guides show higher.
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by aasbury
    Always a bit confusing. But 18.5 is below both so you are fine. Just let it drift down from here - you're fine swimming anytime it is below shock and clear (so you can be seen if you go under water).
    I didn't shock it on purpose. It crept up on me due to the cover and reduction in swimming. I never changed my routine. I did have 89 degree water the other day, though.
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
