Thread: Heat pump questions for an ABG pool
    Hey all,
    Me and my wife were talking today and we think we want to add a heat pump to our pool. Nobody has used the pool in a month because it is to cold. I only really enjoy the pool in late June and July and in August it seems to get a little to chilly for my gang. So I am looking into a heat pump. It is really the only option. I don't have anywhere to put solar panels and Propane is out of the question. So a heat pump seems like the logical answer. I would just like to hear from any heat pump owners their feelings about a heat pump. My main concern is cost!! If anyone would like to share any tip or info, I would really it. Thank you.
    Lomart 21ft round 11,000 gal 52"
    Hayward EC40 Perflex DE filter
    1hp Hayward Powerflo Matrix with micro timer
    Pool Rover JR ABG pool Vacuum (The best)
    Back up pump and filter
    Spectra 3 sand filter/ Promega 1 horse pump with timer
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Heat pump questions for an ABG pool
    The general view is that heat pumps work well to warm the water during the main season but do not do a good job at extending the season.
    Where are you located?
    Nov 2011
    Moberly,MO
    1,010
    NJpoolguy a heat pump unfortunately isn't going to do you much of any good early season or late. You have to much radiant surface to get ahead with a heat pump. Your best bet is either solar or ng/lp whichever you could get most readily.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2012
    Rockland County, NY
    9
    I am in NY, on the NY/NJ border and I just turned off my heat pump. The only reason it is off is we are just too busy to use the pool now that school and sports are in season. Pool was at 80 degrees until we shut it off. You can use the heat pump as long as outside temp is above 50. Yes the cooler the outside temp is the harder the heat pump will have to work, and the longer you will have to run it but you can still use it. You have to work the cost out an decide what is most cost effective for you.
    A heat pump will extend the use of the pool. We were swimming this year prior to any of our neighbors. If you are looking for fast heat for the weekend then a Heat pump may not be the best option. It is a set and forget type of thing. My expierence is limited to one year so far but it has helped as we only get 4 to 5 hours of sun a day on our pool.
    24' Round AG, 54" wall height, 22" sand filter
    1 1/2 HP pump, 104 BTU Hayward Heat Pump
    Rockland County, NY
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by ericjr7210
    Pool was at 80 degrees until we shut it off. You can use the heat pump as long as outside temp is above 50. .
    Thats the other issue. Whats warm to one person is ice cold to another. If my pool was 80 degrees this time of year, for us it may as well be 32! We like ours 88 or so this time of year. No way a heat pump does that in september in northen climes. If youl ike 75-78 degree water in september, sure, it may extend the season. If you like it warmer, not so much.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
