Results 1 to 7 of 7
Thread: help me pick the right pump
    I have been looking at lots of sand filters. Is there a differance between an Intex Krystal Clear 2650 sand filter verses Intex 2650 sand filter that is not a "Krystal Clear"
    I have a 18 x 9 Intex Ultra Frame and will be putting it up for the first time next spring. I have been advised to replace the filter and have decided to go with a sand filter. Amazon has the Intex 14in Krystal Clear on sale as well as the Intex Krystal Clear 2650 for $45 more and the Intex 2650 for $30 more. What would be the best one to buy for my pool that has 4500 gallons?
    I just bought a Intex saltwater system from Target for $99! Can't wait to use it next summer.
    Temporary above ground, 4500 gal,
    38,508
    Re: help me pick the right pump
    Your post confused me. Title mentions a pump, but then your post only discusses filters. Pumps and Filters are 2 different pieces of equipment (although for the smaller above ground pools, they are sold in sets).
    I am not too familiar with these setups, but do know the small Intex pump is almost worthless as far as actually moving any water. I think the 2650 (GPH) is the larger pump, and in general a larger sand filter is better. No idea what the difference between the KC setup and the non-KC ... I suspect nothing.
    Looking at the intex site, the 14" seems to come with a smaller pump ... so would recommend going with the 16" with the 2650 pump.
    Hopefully someone will correct me if I am wrong (or at least validate my suggestion).
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    I would definitely go with the larger system if you are going with intex equipment. Though if it were me I would take a look at the Pentair pump/filter combo units, those are a lot better in my experience.
    Christian's Avatar
    Jul 2012
    304
    Also as far as I am aware the Krystal Clear is the intex salt water system so you may be looking at a combo salt system and filter when you look at Krystal Clear stuff. I could be wrong though.
    I guess I have more research to do. I am not really familar with sand filters and or pumps. Thanks for the inforation I will be looking at other brands and I think I will go to a local pool store to get more information.
    Thanks again
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by rozy
    Thanks again
    Just take notes and come back here to bounce what they say off another few ears.
    - Sent using Tapatalk
    Thanks, That is a good idea!
