Thread: Really basic chem question, excuse the pun...re acid...
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,768
    Hi all. I believe muriatic acid is just hydrochloric acid, right? A pal who is a hydrogeologist dropped off a half-filled 55 gal tank he didn't need from when he cleaned out his shop.
    I couldn't see the percentage anywhere on the barrel.
    Before I use it in place of my hardware store MA, I just want to confirm that it's a) same diff and b) likely to be the same concentration 34% as the store-bought stuff. I will use a third to test first, bUt just thought I'd check to see if anyone happened to know.
    Thanks in advance!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mar 2011
    Sunny Central Florida
    91
    Re: Really basic chem question, excuse the pun...re acid...
    Probably same concentration.
    "Bulk industrial-grade is therefore 30% to 34%, optimized for effective transport and limited product loss by HCl vapors."
    http://en.wikipedia.org/wiki/Hydrochloric_acid
    You won't need to buy acid for a while
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
