Thread: Biggest D.E. and cart filter avaliable
    Guest
    Whats the BIGGEST D.E and cart filter avaiable for a home pool. i want the biggest filter money can buy, im tired of needing to backwash everyday. because my pressure rises 10PSI, then i backwash and its clean, im ready to buy.
    reason i ask is im not sure what to buy yet, i dont want sand, im weighing my options on which, do i want the best filter which is a D.E. or do i want the easier matinence and a cart filter than only needs to be cleaned 2 times a year on average.
    also pump sizeing.
    i have 2 1/2 in suction and return. 2 skimmers and a vac port, all sucking 24/7. how big of pump can i buy, the pump is about 80-90 feet from the closest return, and 135 from the farthest return. would an intelliflo be good in my situation.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Check this this out. Looks like 520 sq-ft for cartridge and 100 sq-ft for a DE. Not sure if they make bigger.
    As for the pump, it doesn't sound like you have a need for high flow rates other than your pool size. Do you find your current pump to be over/under sized for any reason?
    Yes, I would think that the Intelliflo would be a very good choice for your pool. Lot's of flexibility in setting flow rates. Low flow to save money and high flow when you need it.
    Mark
    Guest
    Quote Originally Posted by mas985
    pump is super small , only enough gpm to turn over once aday running 24/7, so i guess i need bigger, it stays clear, but when its dirty it can take upwards of 2 weeks to clear, like at the start of the season when its cloudy, its not suprising to take two weeks to even see the start of the deepend. so the intelliflo is what a 3hp, but variable??
    is 100 Sq enough filter, can i have 2 100 Sq filters???
    Yes, you can plumb two identical filters in parallel. I wouldn't try it with non-identical filters. Also, there are then twice as many things that can go wrong.
    Apr 2008
    Indonesia
    311
    Thunder,
    I use 1 of Hayward 120 SF cartridge and that is already downstream of a Hayward sand. So my cartridge work less.
    I do at least 1.3 turnover times 35,000 gallon of my pool a day.
    My city is polluted and I have divers in the pool about 10 -15 people a week. 1 diver is like 3-4 swimmers bather load.
    I clean my cartridge twice a month at least and I have sand too upstream. Other than divers, the pool is for my own kids.
    If assuming that my bather load plus city pollution combination is 10x your bather load scenario , I still don't think you can get away with only twice a year cleaning based on 1 x 100 SF cartridge, probably more cleaning ....since the cartridge works really well trapping up to 10 micron particles, depending on what brand of cartridge you are using though. DE I have no experience.
    This is just an example, not a real apple to apple comparison though. I clean my filter at 7 psi increase.
    If you get a 300 SF unit maybe you can have extended service, assuming your area is less polluted compared to mine.
    happy shopping
    35,000 GL pool. In Ground. Concrete with all white ceramic tiles. Outdoor but shaded.
    Approx 36 ft by 15 feet. 2HP Hayward Super Pump, Hayward Sand Filter with Zelbrite ( Zeolite ), Hayward Cartridge Filter, Aquamatic Silver+Copper Ionizer ( suspended use since Oct 2008 ), Prozone Ozonator, 2 gram/hr, Analog Flowmeter on pipe
    Back Up Pump & Filter on trolley, Pentair 1.5HP + Pentair Cartridge Filter, Slime Bag 1 micron Jumbo Size, downstream of Cartridge
    Guest
    i just said 2 times a year, because, but it may be more.
    it sounds like DE is the best, so i could do 2 100 sq ft filters.
    could i do 3 or even 4 filters and an Intelliflo, plus a intellichor, and a new booster and polaris?? then automate it?
    about how much am i looking for intelliflow, twin D.E. , booster, polaris, intellichor, and automation???? ballpark.
    THANKS A BUNCH.
