I installed the new iBall Velocity variable return fittings in my pool at the beginning of August and have been meaning to post a complete review but I got very busy at work and couldn't get the time. In the few seasons since I had the pool built, I have tried various types and sizes of return fittings to optimize the energy savings of my Jandy variable speed pump. I found that when I sized the returns to achieve good water movement at lower pump speeds, they were much too restrictive at higher pump speeds. I saw the Youtube video for the new iBall Velocity return fittings and decided that I would give them a try.
I took data before and after the replacement of my three return fittings. I have attached a summary of the data if anyone wants to see a before and after comparison.
For my testing, I used pump speeds which have flow curves in the pump owners manual. These are 1500, 2400, 3000 and 3450 RPM. I also tested at 2800 RPM since that is the normal filtration speed which I have been using for the last couple of years. I have a 3-way valve on the suction side which selects between the skimmers, main drain or mix of both. I generally run the pump with a mix of both and left the 3-way valve in a fixed position throughout the test.
Flow readings were taken with a recently installed FlowVis flow meter which I purchased from TFTestkits. Take a look at this thread
http://www.troublefreepool.com/check-valve-flow-meter-install-t51095.html for info on the flow meter.
The pressure readings were taken from the gauge on the filter. I know it's not the most accurate of gauges but it's all I have.
Watt readings were taken through the control system directly from the Jandy ePump.
Test data is as follows:
[attachment=0:1wuhh0hn]iBall Velocity Data.pdf[/attachment:1wuhh0hn]
Results:
I think that the iBall Velocity returns generally do what the manufacturer claims. I have been able to run the pump at a slower speed and still maintain good water distribution. I am also able to increase the pump speed (for vacuuming or better surface skimming) with lower filter pressures and higher flow than before. Two things that concern me is how well the silicone material will hold up to constant chlorine exposure and what happens to performance as the material stretches out over time.
Also, I'm not sure how to know when the filter needs a backwash using the filter's pressure gauge. My theory is that as the filter gets dirtier, the flow will reduce as a function of the resistance. The iBall Velocity fittings will see the lower flow rate and open up to maintain a constant velocity. I'm thinking that I may need to monitor the pump motor watt reading and/or the flow meter to determine when to backwash.
Hopefully this helps.
