Results 1 to 8 of 8
Thread: Taylor Complete FAS-DPD K-2006
    Sep 2012
    Tampa, Fl.
    34
    Found the above "Subject" test kit on E-bay for $57.95 with free shipping. Is that a good price?
    Any preferred seller you all can recommend to purchase such a kit? Have been depending on a local pool store for my water chemistry, but it is not working out. Have the time and need to take this project on myself. Look forward to some advice/recommendation. Thanks.
    free-form, 13K plaster/gunite IG pool, Hayward Pro-Grid DE filter (DE2820), A.O. Smith 1 1/2HP motor, Rheem gas heater (266A), 4 jet spa, Tf100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Taylor Complete FAS-DPD K-2006
    Sounds like a decent price, but beware. They only give you enough reagent for maybe 4 CYA tests.
    A TF100 costs more, but comes with larger quantities. And a bigger box, which will hold extra tubes and a speedstir. I know this firsthand.
    Either kit uses the same tests, same reagents.
    38,235
    tftestkits.net also sells the K2006 ... slightly cheaper although have to add shipping. Check out their prices for both kits ... the owner of this forum also runs that business ... So support is appreciated if you like the forum.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    Go ahead and get the bigger kit. You can find the link to the tests kits in my siggy. You WILL end up paying more in the end due to having to order and pay shipping on the refills if you buy the smaller kits.
    Kim
    kkendall's Avatar
    Phoenix
    67
    Quote Originally Posted by Richard320
    ... which will hold extra tubes and a speedstir.
    What's a speedstir?
    * 18.5 K Gallon, 8ft deep, IG, Pebble Radiance * Pentair VS 3050 Pump w/420 Cartridge Filter
    * Blue Square Q-360 In-floor Cleaning System * UltraPure UPP25 Ozone Generator
    * Pool startup: 09-04-2012 * TF-100 Test Kit
    http://www.amazon.com/Taylor-9265-Magne ... =speedstir
    It uses a spinning magnet shaped like a pill that you drop inside of the liquid to constantly stir. It is nice for the tests where you have to add a lot of drops, it makes it much easier mix.
    the speedstir fits inside the k-2006 box.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Speedstir - something that isn't needed, but you must have! It really helps make testing easier.
    Quote Originally Posted by thadius65
    Couldn't have said it better myself.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
