Thread: Need recommendation for pump to drain spa
    Can anyone recommend a fast and reliable pump for draining a spa?
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Need recommendation for pump to drain spa
    Might be overkill, but a submersible from home depot will cost about $25 to rent for 4 hours. Should drain it in less than 10 min.
    However, you could probably just use a hose and let it siphon out.
    Is it an attached spa?
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
