Thread: Hot tub ph problems
    Hot tub ph problems
    I have a 250 gallon Catalina Spa hot tub. I have a problem keeping my ph in check, seems to go over 8.2 over night. Trying to keep it at 7.5. with dry acid.
    My alkalinity is at 80 ppm, calcium hardness is 230ppm. Only use diclor for sanatizer and shock. Only turn aerators and pump on when in hot tub for 15 minutes. Is giving up the fight for lower ph worth it or leaving it high going to be harmful to my equipment? Water temp is kept at 100 to 102 degrees.
    Thankyou,
    richardmh
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Hot tub ph problems
    You could benefit from lowering TA further to 60
    Sep 2009
    Greentown, IN
    914
    If your ph continues to rise quickly you should lower your TA ... using dry acid as you mentioned you have, or muriatic acid (cheaper and found in most hardware stores). Once you have it down, you can add borates to your water to help maintain your TA & ph even further.
    Lowering your TA means lowering your ph to about 7.2, let it rise w/aeration and repeat until your TA comes down. Ph will tend to drift up w/aeration especially if TA is high.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Mar 2007
    San Rafael, CA USA
    12,082
    If you lower the TA a lot, I'd also recommend adding 50 ppm Borates since that will provide additional pH buffering without adding carbonates that lead to the carbon dioxide outgassing that is raising the pH from aeration.
    i don't have test strips for borates. i wondering if you could tell me by weight or volume of borax it would take to get 50ppm for 250 gallons of water.
    thankyou
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I recently did this. Use the http://www.poolcalculator.com/ and enter your hot tub gallons, then the target of 50 ppm.
    You should get about 10 ounces of boric acid or 14 ounces borax roughly and about a cup of muriatic acid. Depends on what product you're using.
    But don't take my word for it, use the calculator!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
