Results 1 to 13 of 13
Thread: Chlorine drop test
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    Chlorine drop test
    When I add my DPD powder I don't get any change in color. Is this because I have no chlorine at all? My powder was old and turned black so I ordered a new container and it does the same thing with the new powder as well.
    19000 gallon inground fiberglass pool
    Hayward Pro Series Sand filter S244T 62 gal/min
    Whisper Flow WFE-2 / 011511 1/2 hspr pump
    Aqua Rite AQR Pro SWG, T15 cell for 25000 gal
    22,369
    Re: Chlorine drop test
    Do you have an OTO test kit? If so, check the chlorine with that. If there's any chlorine in there it'll turn some color.
    What are you running the swg at?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    FAS-DPD can report false negative (so I have read) and as Bama says above the OTO test (yellow side of the Taylor K1000 test block) is very reliable for showing if you have any chlorine.
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    I have the TF-100 kit and it includes the Taylor K1000 test block. I did the test with that as well and I have no chlorine. My question, I guess, is more directed towards the R-0870 DPD powder. How come it doesn't change to pink (or any color) when I add it?
    22,369
    If there's zero chlorine in the pool it won't change color because there's nothing to bind to. There has to be chlorine for the dye to work.
    Quote Originally Posted by fordsbyjay
    If you added the two scoops it pretty much means chlorine is zero. Put a couple drops of bleach in the sample and see what happens.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    Ok thanks. I guess I have just never been that low before that there was no color change. I figured I was doing something wrong or there was a problem.
    37,391
    Well ... technically you are doing something wrong and there is a problem ... not checking the FC often enough and letting it drop to zero
    At this point, it seems that you need to start performing the shock process ... or at least raise to shock level and perform the OCLT to determine if there are organics in the pool consuming the FC as fast as the SWG can generate it.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by march2012
    Another option if you have chlorinated tap water - drop some into the sample when you see no color change - it should immediately turn pink when you add the chlorinated tap water.
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    I went and had my T9 cell tested and it Failed which I guess explains the no chlorine situation...
    thank you for the replies.
    Jun 2012
    Mint Hill, NC
    2,589
    Grab some bleach while you are waiting to get it fixed or replaced.
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    Quote Originally Posted by UnderWaterVanya
    That is exactly what I did. Thanks.
    If you don't get a color change when adding the R-0870, you should then add 5 drops of R-0003 to see if you have any combined chlorine.
