Thread: Nature2 Fusion Inground
    Sep 2012
    Dallas, TX
    30
    Hello,
    Has anyone install Nature2 Fusion Inground system? Does it really reduce the level of Chlorine used? Is it worth it?
    Thanks
    Hean
    13,500 gunite fresh water pool and spa with Jandy variable speed pump, cartridge filter, and heater
    13,500 Gunite with Pebble Tec Pool and Spa, Jandy 2hp Stealth epump, Jandy 1.25 hp pump for water feature and bubbles, Jandy CL 460, Polaris 280, DEL Eclipse, Jandy LRZ 400k TF100 Liquidator
    22,548
    Re: Nature2 Fusion Inground
    Welcome to TFP.
    There have been many people that have installed the Nature² and then uninstalled it or just left it empty. It adds metals to your water and doesn't actually reduce the amount of chlorine you should keep in the pool.
    Spend some time reading here and learning to maintain your pool and you'll be much happier than with any of those type systems.
    You can search for Nature2 and find a lot of good reading.
    Bottom line is that you don't need it, and it costs you a lot of money in the long run.
    Sep 2012
    Dallas, TX
    30
    thanks very much Dave...
