Thread: Newbie with a question
    I am going to be closing my new pool for the first time and I'm not sure how to handle the cover. I have an oval abg and only one half (long side) has a deck butted up to it; the other side of the pool has nothing against it. I bought a standard winter cover but it dawned on me that the wire cord or the clips won't work on the deck side of the pool. Any suggestions?
    14k gallon oval agp, sand filter, 1hp pump, BBB method, K-2006 Test Kit
    Roanoke, VA
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Newbie with a question
    I have attached a hook on each side of my deck for the wire to hook/tie into on each side. Has worked fine for 3 seasons.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I do the same as dmanb2b and for the section by the deck (20 feet in my case) I pull the cover between the deck and pool then use ropes and bungees to hold it taught.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
