Thread: AA treatment backwash into grass?
    Oct 2010
    michigan
    284
    When i close my pool in october, I was wondering if i could do a AA (absorbic acid) treatment. would it be safe to backwash onto the grass?
    live in michigan, when i close the pool, i drain 1/3 of the water, thus if i do an AA treatment i would eliminate 1/3 of my stains.
    thanks
    steve
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: AA treatment backwash into grass?
    It shouldn't have any ill effect on the grass.
    Not following your logic re: the 1/3 of the stains though
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Melt In The Sun
    It gets washed away rather than sequestered...
    -sent with Tapatalk 2
    Oct 2010
    michigan
    284
    I have very light staining, Yes 1/3 will be washed away.
