Results 1 to 20 of 20
Thread: Pool Calculator Update?
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Anyone know or still have a contact within pSIFlow Technology Inc? Would like to recommend an update to the calculator to account for the new 8.25% concentrated bleach. This is not currently an option in the "Effects of adding chemicals" section at the bottom.
    I sent an email to them. Will update if I get a response.
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    Jan 2012
    West KY
    243
    Re: Pool Calculator Update?
    Already got a response of sorts:
    Delivery to the following recipient failed permanently:
    info@poolcalculator.com
    Technical details of permanent failure:
    Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 550 550 No Such User Here (state 13).
    looks to be abandoned
    TF100 Test Kit
    SpeedStir
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    In the calculator you can put in any percentage you want. It's only below in the "Effects of adding chemicals" that it is even an issue.
    chiefwej
    Jan 2012
    West KY
    243
    Quote Originally Posted by chiefwej
    Right, but from that portion of the calculator you can't tell it X number of ounces of X % bleach. You can specify the bleach % and the current and desired FC level, but not the volume of said bleach to find out how it will effect your overall chemistry. I know one could play around with desired "Target" inputs until he reaches a volume similar to what he is checking, but that's a bit of a pain
    For example, if another user looking for help posts they "added X number ounces of 8.25% bleach and their FC increased to X" I want to be able to quickly check the Pool Calc to see what their FC "Should Have" ended up.
    TF100 Test Kit
    SpeedStir
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    What happens if it goes down? Does anyone have the detailed info to build a new site with similar features?
    Jan 2012
    West KY
    243
    there is a version for iOS as well as SimplePool for Android. Both work well, but the pool calculator site is probably the easiest to use.
    TF100 Test Kit
    SpeedStir
    38,524
    JasonLion has a copy .... he wrote it afterall. In fact, when it was not working a few months back, he put up a temporary version hosted here.
    The problem is ... he sold it to them; so his rights to putting out a new version is questionable ... unless maybe it is completely abandoned.
    Jun 2012
    Mint Hill, NC
    2,589
    The site itself is something he sold - I get that. The math and the idea are not things that someone else would be unable to do. The format and organization of the site would be different but the basic ideas should be something that anyone could create with the right formulas - without violating the existing site's rights.
    Unless there is some math that is proprietary?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Contact info per their web site:
    Address Info
    988 Longmont Ave, Suite 200
    Boise, ID 83706
    United States
    Other Contacts
    Phone: (208) 287-4664
    Email: support@psiflow.com
    chiefwej
    mas985's Avatar
    Pleasanton, CA
    11,742
    I have a Google Docs spreadsheet that you can try if you like. It does most of what the Pool Calculator does and it is located here:
    https://docs.google.com/spreadsheet/ccc ... kt4SVlZX3c
    You can't edit that version but if you choose File -> Make A Copy..., you can then edit the copy. But you will need a Google account or download as Excel should work as well although the History Log script won't work. I checked it against the web version and I think everything is the same but let me know if you find any problems.
    Mark
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I've saved the html page locally so that if my network goes down or I'm out at the pool with the laptop out of wireless range I can still use the Pool Calc. I got into that habit when I was on dial-up. Now I'm on a line-of-sight wireless broadband that does occasionally go down. When you live in the boonies you get inventive
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    I would love to see the Pool Calculator updated so that going from top to bottom, the *first* thing you input is your pool type, your chlorine source and whose recommendations you want to use, instead of it being way down at the bottom. Then you input your test results.
    mas985's Avatar
    Pleasanton, CA
    11,742
    That is one of the reasons I put it in a spreadsheet so you can customize the sheet anyway you want.
    Mark
    Dallas
    51
    Quote Originally Posted by mas985
    Thank you for this VERY much
    Greg Watson
    15,500 Gallon Freeform IG Martinique Luna Quarts Pool, Jandy CL580 Cartridge Filter, Jandy Stealth Pump, Rainbow 320 Inline Chlorinator and Polaris 280 Pool Cleaner
    Jan 2012
    West KY
    243
    Sweet! Many thanks!!!!
    TF100 Test Kit
    SpeedStir
    Jul 2013
    MA
    17
    This Spreadsheet link is dead any chance it was uploaded somewhere else? I don't like the choices for android phone and I dont like having to enter my pool size and my current values when they havn't changed so bookmarking doesn't work so well for me...
    10k Gal, AG Vinyl (Intex 22' Metal Frame), RP2500 pump, Intex B Filters
    mas985's Avatar
    Pleasanton, CA
    11,742
    Sorry, I had to abandon the Google Docs spreadsheet but all my spreadsheets can be found in the link in my signature.
    Mark
    Jun 2013
    East TN
    309
    Are you talking about this one? It has already been updated.
    calc.html
    It has 8.25% and the 121oz jug size.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    mas985's Avatar
    Pleasanton, CA
    11,742
    I believe that Cordova was referring to the standalone spreadsheet I created which basically does the same thing as the web version. Some prefer to use that so they can customize it. It also has a log feature so you can save your measurements.
    The direct link is here:
    Chemistry Calculator (Excel)
    Chemistry Calculator (Google SS)
    Mark
  20. Back To Top    #20
    Jul 2013
    MA
    17
    Thanks for the link
