Thread: Removing steps and ladder
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    We are finished swimming for the season. I'd like to go ahead and close, but for the sake of a good opening next spring I will let it go for awhile until water cools down. But in order to access the pool and stir things up well, I need to be in the pool--which is now a temperature problem.
    Yet at least with the steps in, there is a chance I can be brave every few days & go in to aerate and scoop a little debris, but I want to get the steps out now before it's hugely painful temp-wise to do so. But I would cut off my in-pool access to keep it clean (deck not built yet).
    Suggestions?
    Pool: 27' x 52" AG, about 16,500K, cartridge filter
    Waterway 175 sq ft 1.5 hp pump 2-speed
    Deck first of June!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Removing steps and ladder
    Quote Originally Posted by maryann79
    Suggestions?
    Buy a cheap AGP ladder (craigslist) to use after the steps are removed. They are easy to pull out and wouldn't require you to get into the water to do it once it got too cold.
