Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: I humbly ask you to opine on a new Central Texas build.
    Austin, TX
    21
    Hi there,
    We are located in Central Texas and we have finally decided to become a pool owner. Needless to say, this forum is undoubtedly one of the first stops one has to make before signing.
    16x40 fiberglass pool and rock dig installation $35,750
    21,000 gallons
    3'10" - 6'6"
    Backfill materials and hauling charges $3,000
    Bond beam with rebar for stone decking $1,200
    Electrical $1,300
    ALL 2" PLUMBING ON SKIMMER AND MAIN DRAINS/SUCTIONS, ALL 2" ABOVE GRADE, 1 1/2" PLUMBING ON RETURNS, WATER FEATURES, DECK JETS AND SLIDE. Telescopic pole, leaf net, wall brush, vacuum hose and head, skimmer plate, test kit and start up chemicals.
    Skimmer and 3 returns.
    Perimeter tile allowance $2,700
    G-force slide with paver anchors and installation $3,850
    Waterfall: 1 x 48" sheer descent and 2 x 24" sheer descents.
    24" $350 each and 48" $500. Plumbing, valves and lines $300.
    2- DECK JETS $250 EACH INCLUDED
    Lighting: LED lighting pal-2000 x 5 with remote control and timer $1,695
    Easy touch control 4 function installed $1,300
    Pentair cartridge filter CLEAN & CLEAR 320
    Pentair intelliflo VARIABLE SPEED VS- PUR-10-1018
    Pentair intelliflo salt system INTELLICHLOR IC40 $1,295
    Pool cleaner KREEPY KRAULY PROWLER 830 $1,136
    Propane gas heater MASTER TEMP 250k BTU $1,700
    TOTAL $56,426
    5% discount if paid in full $53,604
    Thoughts?
    (Apologies if you may have seen this post on another forum)
    21K gallon IG Fiberglass pool (installed January 2013), Pentair Intelliflo VS, Pentair Clean & Clear 320, Pentair Intellichlor IC40, Pentair Ultra Temp heat pump 125K BTU, Kreepy Krawly Prowler 830, Pentair Easy Touch 8 with remote, G-Force 2 slide, TF100 test kit.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: I humbly ask you to opine on a new Central Texas build.
    I would be concerned about a SWCG with a stone deck. Is your PB certain that the stone chosen won't have issues with the salt?
    Mar 2011
    Houston, Texas
    413
    I'd get a larger heater and a larger filter. IMO, it would be worth the extra cost.
    As stated above, be careful with the natural stone and the SWG. I sealed my travertine coping and I haven't had a problem--yet. I've heard some horror stories about people with flagstone coping and a SWG.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    It's also usually preferred to have a 2nd skimmer. And I could be wrong, but 5 lights seems extreme in this size pool?
    Sounds like you will have a great pool!
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    Austin, TX
    21
    Good catch JohnT. Didn't notice that. We know about the issues with salt and stone and are actually using Belgard concrete pavers and coping. Supposedly these hold up to salt water. The PB is not doing the deck but is allowing us to buy the pavers wholesale through him.
    Austin, TX
    21
    HouTex - Will look into that, thanks!
    Bluegrassman - Will ask about a second skimmer. Agree on the lights. He originally said 4 and then 5 appeared in the contract. Thanks.
    Jan 2012
    West KY
    243
    Just for comparison, I have 2 LEDs, one in each end of our 18x36 and it is definitely plenty. Money saved by cutting those extra lights would help cover extra skimmer, etc.
    TF100 Test Kit
    SpeedStir
    Jan 2012
    West KY
    243
    Quote Originally Posted by Sammyw
    Sounds much better than stone in regard to using a SWCG. We have stamped/stained concrete coping. Should hold up well to the salt.
    TF100 Test Kit
    SpeedStir
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Does this mean that the main drain is plumbed to the skimmer or separate or that there is no main drain?
    If you aren't aware of it - this will increase aeration and cause pH to rise even more than it wil already with SWG. These are pretty but you will be using acid to lower pH.
    Jan 2012
    West KY
    243
    But the sheer descents are so pretty! I love mine. We don't run it all the time, but if you need to raise pH, it sure is a nice way to do it! But seriously, one will have to add MA on a semi routine basis anyway due to the SWCG, I find that it hasn't increased the amount I use by too much. I'm still using the first 1 gallon jug of MA I bought this summer for about $7 or $8 at Lowe's
    TF100 Test Kit
    SpeedStir
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Bluegrassman
    Voice of experience vs. Voice of Confusion. Listen to this guy ^^^^ I don't have a waterfall or an SWG. I do read about it and hear about it and thought it was more of an issue than it must be.
    Jan 2012
    West KY
    243
    LOL, Mine is a voice of only one season of experience! Hopefully someone with much more experience than me will chime in too.
    Plus, his waterfall sheer descents total 96 inches compared to 42 inches on mine. I have a 12/18/12 configuration. I wonder if that would mean his pH rise would be twice what I see?
    TF100 Test Kit
    SpeedStir
    Austin, TX
    21
    Holy ****, you guys have me confused. I thought I knew a decent amount of info but apparently not. I"ll be doing a fair amount of research on the main drain and ph increasing issues as well as the MA issue.
    Jan 2012
    West KY
    243
    Sorry Certainly don't want to add confusion. You will be fine. Just do a little more reading on this site. Don't worry. Your pool will be very easy to manage.
    TF100 Test Kit
    SpeedStir
    Austin, TX
    21
    Oh, please don't be sorry. I made the comment mostly in jest. I will most definitely be doing a lot more research on this site as well. Thanks for enlightening me.
    Apr 2012
    Klein Tejas
    249
    I think your pool builder has plenty of mark-up on that pool and equipment.
    Are you sure you want fiberglass? In Texas, your choices of fiberglass installers is limited.
    However, there are gunite builder-a-plenty.
    I'm frugal and would shop around.
    What's the "paid in full"? A cash discount? Or they want it upfront? <never>
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    Austin, TX
    21
    bigdav160, you're correct about there not being many fiberglass installers around here. We're beginning to realize we may have to go gunite. Just liked the low maintenance, low chemicals less long term expenses that fiberglass tends to offer.
    And yes, it was pay in full upfront.
    Vinoveritas's Avatar
    Nov 2011
    Austin, Texas
    46
    I was able to install a slightly smaller inground pool with a spa and incredible stone work for less than what you've been quoted. Read lots of build threads and get lots of bids.
    Where in Central Texas are you?
    16,000 IGP with Spa - Quad 80 DE - WET Midnight Sea Satin surface - Intelliflow VSP (3hp) - EasyTouch 4 - TFT100 w/ Speed Stir (best thing evah)
    Austin, TX
    21
    We're in Austin, Tx.
  20. Back To Top    #20
    Missouri City, TX
    73
    We just had a 14x38 inground gunite with pebble sheen installed just outside of Houston for around $63k but this included a small outdoor kitchen, sprinkler repair and also a mosquito misting system. The pool has Flagstone coping and the back 38' wall is 16" raised stacked flagstone with 2 sheer waterfalls. Just for comparison, we have 2 LED lights in the main pool and 1 LED light in the 7' x 7' spa.
    I think 2 LED's in the pool and 1 in the spa would be plenty in your pool unless you have some strange angles that would cause shadows in the pool, in that case, maybe a few smaller spa sized lights might be needed.
    Are you getting a SPA? I don't see it listed in the quote - we have a 400K heater. If you do not have a spa, I would think about if you really want a heater at all - I would recommend the larger heater either way.
    I would never pay for something like this upfront to get a discount - to many things can go wrong and you have no easy recourse if the PB has all of you money. I would also tend to shy away from any PB that would try to get all of the money upfront.
    20,000 IG WetEdge Satin Matrix Northshore Plum, Filled 8/24/12
