Results 1 to 12 of 12
Thread: Can't get rid of mustard algea
    May 2008
    North East Mississippi
    17
    I began the season with a green pool, it's all clear now, but I think I still have mustard algae which I"ve had since last season but never completely got rid of. It looks like there is dirt on the bottom and sides of my pool, when I sweep it it looks like a puff of smoke, the water gets slightly cloudy then it settles again on the bottom of the pool. I have kept the FC up but it's still there. I'm using granular chlorine from wal-mart as I am a newbie and I already had it before I began reading this forum and gained knowledge from all of you. I plan on getting bleach when I run out. My test kit is not in yet either, so I don't know my exact numbers, it is ordered and should be here any day now. Just want to get rid of the stuff already!! Any suggestions.
    Thanks!
    Southern Girls Pool- In ground, 18X36 vinyl liner, approx 27K gallons with sand filter, booster pump for polaris, and Jandy gas heater in Mississippi
    30,421
    Rather than guess at the issues, I think your pool will get cleared more quickly if we all wait for your test results.
    It's hard to tell you which direction to take when no one is sure where you are.
    Mustard algae is reasonably rare but is frequently mistaken as a problem in many pools.
    While your waiting on the kit, see if you can google some pictures and descriptions for mustard algae. It may be that you've got remnants of green algae hangin' around as dead algae.....it's not always green.
    Oct 2007
    Lafayette, La
    39
    I am uncertain whether I have a mustard algae myself- same dusty looking bottom and sides of pool. this am readings were TC-4
    CC-0
    alk-100
    ph 7.4
    calcium 180
    cya-50
    temp 82
    15,000 gal fiberglas pool
    About 14 days ago I used Vit C and metal out for metal stains I also added Polyquat 60 when I treated because i dropped TC to 1 - I began adding bleach 24 hrs later (stain all gone) adding it slowly for the next week never getting above 3 ppm. This weekend the water looks a little cloudy but my readings appear OK Took water to pool store this am and they verified the reading I have been getting. They recommended using a water clarifier but I did not- can I have mustard algae or any algae without showing any CC? What would you do?
    Are you sure it isn't just "dead" algae? when I have dead algae it always does that puffy cloud thing./ Vacuuming very very slowly usually takes care of the problem.
    The granular chlorine from walmart has CYA in it, it is the same as Trichlor. Be careful with it, or you will end up draining your pool.
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    Oct 2007
    Lafayette, La
    39
    Thank you edbson- I vaccumed yesterday and it is back to being dusty today. I only use bleach now- I had a horrible CYA problem 2 years ago. I am glad you mentioned the granular chlorine from Walmart because my husband had looked at that- will tell him it is a no-no. Does anyone know if I can have an algae problem with a 0 CC reading?
    30,421
    edbson speaks true words of wisdom!!
    I would add to that to bring your FC up to about 20ppm, brush the sides of your pool, vacuum. hold that FC at 20ppm by testing and re-adding for a couple of days or so and I'll bet that'll all go away.
    Yes, you can have algae with little or no CC's. That's fooled me more than once but it can work that way.
    Mustard algae can do everything you describe and so can very fine dust, pollen, or algae that is right on the edge of growing and being killed off just as quickly. Dust can stay in suspension for days, slowly settling out to the bottom a little each day. I get that every time there is a significant wind blowing stuff into the pool.
    You can have algae without any CC.
    May 2008
    17
    Got my test kit!!
    I received my test kit today, here are my numbers
    FC-41
    CC-.5
    TC 41.5
    PH-7.2
    TA-110
    CH-130
    CYA-80
    I have no idea what these numbers mean but think they may be good please advise.
    Lanice
    Your numbers look good for a vinyl pool, plaster would need more CH. If it is mustard algae you are doing the right thing to fight it, very high FC levels and brushing. Keep the FC level up above 40 for 24 hours after the FC level holds overnight and that should take care of it. Mustard algae can be very persistent and reappear over and over if you aren't very through with brushing and high FC levels.
    When you say "on the sides" does that mean that it is appearing on vertical surfaces, or only on sloped surfaces? Vertical surfaces would mean mustard algae for sure. If it is only appearing on sloped sides, then there is a chance that it might be pollen.
    For details on what the various test results mean try the What to test for and what the tests mean sticky.
    It would be great if you could post some basic specs for your pool and equipment in your signature. That will make it simpler for us to answer your questions completely.
    May 2008
    17
    I have updated my signature to include the specs on my pool. I brushed again this afternoon and really took a look at the stuff on the bottom and sides of my pool, it is only on the sloped sides of the deep end and bottom of the pool. It is not on the vertical sides in the shallow end. I have kept my chlorine high for some time now, about a week. If this is mustard algae shouldn't it have been gone by now? Thanks again for all the help. I feel I have some power now over my pool where as before it had the power over me.
    Lanice
    30,421
    Lanice,
    Test for FC again tomorrow morning and post that number. That'll be helpful.
    What are you using to chlorinate?
    I think it is pollen. Mustard algae usually vanishes at the first sign of shock levels of chlorine, only to reappear when the chlorine level goes down. Pollen can look and behave almost identically if you don't have a microscope and pollen remains even at high FC levels.
