Thread: Causes for raising TA
    Oct 2007
    Valrico, FL
    542
    The TA in my pool raises slowly over time. The pool is about four years old, and I do not add baking soda. About once a year I have to perform the TA reduction process. I would like to know possible causes of increasing TA.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Causes for raising TA
    It's probably from your fill water. What is the TA out of the tap?
    Jun 2011
    Long Beach, CA
    2,790
    Mine rises due to the fill water is higher in TA than what I keep it at. What level do you keep your TA at and what level is your fill water? You may as well post all the test results; FC, pH, TA, CH, CYA.
    Mar 2007
    San Rafael, CA USA
    12,082
    Remember that with evaporation and refill, whatever is in the fill water gets added to the pool. So even smaller amounts of TA or CH in fill water will increase those values in the pool. It's with drain/refill where only higher values in fill water increase values in the pool.
    Oct 2007
    Valrico, FL
    542
    I will have to get back to you on the fill water measurements.
    As for the pool, I try to keep pH at 7.6, FC at or greater than 5, TA was reduced to 50, CH is at 280 and CYA is at 70.
    During the summer months, I do not fill the pool, rather usuallt have to drain some from the summer rains. Even during this period TA raises.
