Results 1 to 15 of 15
Thread: Where to buy gravel for sand filter
    Jun 2011
    Fullerton, CA
    31
    We are almost at the end of the process of remodeling our pool. As part of the remodel, we replaced all the 40 year old equipment. This included changing the stainless Purex DE filter to a Triton II sand filter. This due to lower maintenance. I've decided to use both gravel and sand in the TR-140, however, I cannot find a place to buy the gravel. The Triton manual states the gravel should be 1/8" to 1/4" in size. Any suggestions of where to go? I've found the #20 Silica pool sand at HD.
    Thanks.
    22,553
    Re: Where to buy gravel for sand filter
    Most places have washed pea gravel that meets that specification. I bet even HD has it.
    Jun 2011
    Fullerton, CA
    31
    Thanks. I will make a more thorough check at HD for the gravel.
    Jun 2011
    Fullerton, CA
    31
    I guess I'm out of luck. Neither HD nor Lowes carry that small of pea gravel. Unless there are other suggestions, I most likely will have to call the construction material suppliers. That I'm guessing will not be washed gravel. Tomorrow plaster is starting and after that pool startup. Ugh, I'm down to the last minute and still don't know where to go
    4knights's Avatar
    NE Kansas
    419
    Menards, or maybe Walmart in the aquarium section or lawn and garden. Possibly a landscape store that deals with KOI ponds- they use gravel in the filter system
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jun 2011
    Fullerton, CA
    31
    Thanks. i will try Walmart and look for some koi pond dealers. Menards isn't around in my area.
    Jun 2011
    Fullerton, CA
    31
    I ended up going to Thompson Building Material for getting the gravel.
    Aug 2010
    Dallas, TX
    4,052
    Mine is filled with just sand. Does the 140 not have this option?
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by RobbieH
    You can use sand on any sand filter. The nice thing about bigger sand filters is that, because of their large size, you can use pea gravel to cover the laterals. This helps prevent lateral clogs and breakage, and makes a sand change much easier.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Quote Originally Posted by Qwaxalot
    I thought sand really next to never needed to be changed? What sort of problems would require the sand to be changed?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    I'd guess even if you never changed it. Cleaning would be easier with gravel protecting the lateral from the hose end.
    - Sent using Tapatalk
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by YippeeSkippy
    Sometimes it gets gunked up and calcified enough that it's just not worth the effort of cleaning it.
    Aug 2010
    Dallas, TX
    4,052
    Wouldn't the sand work its way down through the gravel voids anyway?
    Qwaxalot's Avatar
    Jun 2012
    439
    One would think so, but this doesn't seem to be the case. On the other hand, I've never changed the pea gravel.
    Jun 2012
    Mint Hill, NC
    2,589
    Some might but the gravel would still protect the laterals and potentially prevent channeling.
