Thread: Screwed up CYA What Other Harm Have I Done?
    I have been in the process of converting spa to BBB the last 2 weeks and have had a couple of slips but I think I'm close.
    Numbers taken today
    FC 4
    CC 0
    PH 7.7
    TA 60
    CYA 100
    Borates 50
    First the obvious, my cya is to high. This happened when I was adding dichlor using old test strips. My T-2600 had run out of reagent. So I way over shot FC and CYA. This fix seems to be drain water and refill but how much? My spa is 510 gallons.
    TA is low but when I raise it PH goes up so I add MA and TA and PH go down. I aerate to raise PH but then TA stays low?
    Thanks for the help Jim
    17500 gallon Sharkline Morada PUR RTR 18X40 54 tall, 1.5 Hayward cartridge filter,
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: Screwed up CYA What Other Harm Have I Done?
    Folks typically shoot for 50CYA so half is probably good. At least it's not your 17.5k pool.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    38,483
    what chemicals are you using for your pH and TA adjustments?
    Posted from my Droid with Tapatalk ... sorry if my response is short
    To lower PH I'm using MA. To raise TA I had a product called akalinity up.
    My 17500 has been flawless all year thanks to TFP. I will be signing up for a lifetime membership tonight.
    Thanks Guys/Gals
    38,483
    usually TA up is just baking soda ... which has a very small affect on the pH. Surprised that you saw the pH rise.
    Borax will raise the pH with minimal TA effects.
    You can see what should be happening at the bottom of poolcalculator.
