Thread: PSI Loss
    SW Georgia
    300
    PSI Loss
    In the last week my PSI at the filter has dropped from 13psi to 9psi. I can only think of three things that my be the problem:
    1. Gauge is bad
    2. Pump is going bad
    3. Blockage in pipe between skimmer and pump
    Are these the only reasons or have I missed some?
    Replacing the gauge is easy and cheap.
    How can you tell if it is the pump or not?
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: PSI Loss
    Quote Originally Posted by jasonknox
    1. Gauge is bad
    Any air in the basket?
    I recently figured out that my suction side valves were not all the way open and before opening them I had minimal but not zero air in the basket. After opening them and getting rid of the air, my pressure jumped up 2.5 PSI.
    SW Georgia
    300
    Re: PSI Loss
    There is no air in the basket and I actually checked it with all supply valves open (two skimmers, main drain, and dedicated vacuum line).
    22,553
    Re: PSI Loss
    Partial clog in the pump impeller!
    Have you checked to see if it clean?
    SW Georgia
    300
    Re: PSI Loss
    Nope, I did not consider that but I will certainly check it. Thanks.
