Results 1 to 12 of 12
Thread: Questions for first closing
    I've searched and searched but can't seem to find the answers to my specific questions. I apologize in advance as I'm sure this has been covered on here.
    This is my first closing so sorry for the newbie questions:
    1. How do I drain below the return? Do I need one of those submersible pumps to do that since my filter will only drain the water up to the skimmer?
    2. In regard to air pillows, I think I'm going to just go with a large inner tube. Should 1 be enough for a 30' round pool? Should I just tie some twine around the inner tube then secure it to the top rails?
    3. With the large inner tube, if the water is below the return and the inner tube is on the surface of the water, that won't really give me much of a peak in the middle. Seems as though the cover would probably sit relatively flat or maybe a very slight peak in the middle. Is that what I want?
    4. Should I use Gizmo even though there won't be water in the skimmer?
    5. Am I suppose to use either a cable/winch OR cover clips OR wall bags/bleach bottles? Or should I use a combination of all 3?
    6. If I get a cover pump does where does it go? Does it stay on top of the cover at all times? If so, where on the cover? Near the middle or near an edge like where my pump/filter are? The hose should stay attached to it all winter. Can't the water in the hose freeze if it gets really cold?
    7. I live in New England. The water in the pool will freeze. That's okay right? There's no way to make it not freeze correct?
    Sorry for all the questions. I'm trying to close myself. Will probably wait a couple more weeks though...
    Wilbar/Sharkline Tahitian 23,900 gallon 30' Round AG, Hayward 1HP 2-speed pump, Hayward 300# Sand Filter, Taylor K2006c.
    Jun 2012
    Blaine, MN
    106
    Re: Questions for first closing
    I'm new a pool owner also so am curious to see what everyone says. Although I can answer #1.
    #1 question - use a garden hose to siphon. My husband used a shop vac to get the suction started.
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Aug 2009
    SW Wisconsin
    518
    take this opportunity to backwash your filter system, and drain to waste until the water is down in your skimmer. Once that is done, you'll need to either start a siphon hose (by sucking on the end of a hose to start draining) or using a submersible pump connected to a hose. I prefer the latter! I drain a good 3-4 inches below my return.
    Save your money and don't buy air pillows, my experience shows they NEVER make it through a winter. Inner tubes are good, and what I use now. I use 4 of them tide together and placed in the middle of my 33ft diam pool They support the center nicely. I use some lightweight nylon cord to secure them to each side of the pool so they stay centered.
    You don't want a large hump really. you are just looking for support for your cover so it doesn't sink over the winter. Trust me, large winter covers are **** to get out of a pool once they are filled with water and have sunk in.
    If you've drained down, you don't need a gizmo
    I have a cable/ratchet device on my winter cover..I crank it down tight and then bungee cord a gallon bleach jug with water every 6 feet or so..works for me. I've never tried the clips
    a cover pump is only placed on the cover when you need to pump water off. So you'd put it where water has collected. Don't leave it on your cover, it'll freeze and be ruined.
    It will freeze! Get water out of ALL of your plumbing, hoses, skimmer, return, etc. Take your stairs or ladder out as well. It WILL FREEZE SOLID, and that is normal.
    Hope that helps ya a bit.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jun 2012
    Blaine, MN
    106
    Can I get some clarification here? Our pool installer closed the pool last year as soon as it was installed and I'm having some questions about things he didn't do.
    - no air pillow or tube last year. Is it necessary? What's the benefit? Granted, we didn't have a whole lot of snow last year so maybe that's why the benefit isn't as obvious to me right now.
    We siphoned ours several times last year because of heavy rains and ducks swimming in the water before removing it, is that why I'm not seeing the benefit?
    -our installer just used the cable ratchet system. Again - is it necessary or helpful to get the cover to last another year or two? And now we have a deck around 3/4 of pool. Just enough clearance to get the cable around the edge. Where would I attach teh bottles if needed?
    blondemarcello
    Minnesota
    22,551
    I use bleach jugs filled with water. I don't use the cable at all. I hang the jugs from the grommet holes in the cover. I use bungee cords to hang the jugs, but small rope or large twine would do.
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    You don't have to suck on a hose to start a siphon. You can submerse the hose to fill it, keep one end in the water, plug the other and place it lower than the water level, then unplug it.
    10 year old 18x32 inground, vinyl liner 1 year old, 25,000 gallon Grecian, Hayward ST244 Sand Filter, 1hp Hayward pump, Diving board, Side Steps, Koolcrete decking located in middle [s:37hekvij]earth[/s:37hekvij] Georgia.
    Do I need more than one inner tube? I was thinking of just getting (1)10.00x20 size which is a huge one made for tractor trailers. Is there any benefit to getting more than one? I would guess it's probably about 3.5-4 feet across.
    Also, a couple of pool closers are saying I don't need to drain down if I have a skimmer plate and a gizmo, but that's not recommended right? Is it because those skimmer plates tend to leak?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    For initial drain down - why not just plug the vac hose into the skimmer outlet and dangle it (properly filled with water) into the pool and just pump as low as you want to go?
    Thanks for all the replies, but does anyone know if I'll need more than 1 inner tube? The one I'm thinking of getting is 48" across(the 10.00x20). There's another huge one that's 60" across but I can't seem to find it locally and don't want to pay $15 to have it shipped on Ebay.
    So you don't use the cable/winch or cover clips? You just use the bleach jugs? It holds up fine in high winds? This would be pretty ideal for me because it would be easy to just remove a jug and access the water to periodically check it & test it which is something I wanted to do since it's my first winterization.
    22,551
    No cable or winch for me. However we don't, as a rule, have what's considered high winds. We have some 20 to 30 mph winds, and those aren't too frequent. Higher than that only happens during a thunderstorm.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by impulse22281
    You don't have to, I hardly ever do on any of the above grounds I close anymore. Just plug off the return with either a rubber compression plug or threaded plug whichever fits better for your pool.
    I don't use pillows of any type, your pool won't explode from the water expanding. Regardless pillows are floating on the surface so they don't absorb much expansion anyways.
    N/A see above
    Instead of a Gizzmo I would use an Aquador or skimmer plug, then detach the hosing from the skimmer
    http://www.amazon.com/Aquador-Pool-Skim ... ds=aquador
    http://www.amazon.com/Above-Ground-Skim ... immer+plug
    I typically get by with the wire/winch. If it seems like air is getting under the cover you can use some clips as well. I'm not a huge fan of bottles hanging as it usually tears the grommets out of the cover over time. Water bags work well for when the decking is too close the to pool to get the cover in between.
    The pump would go in the middle of the cover. Rule makes an automatic pump that is pretty good and it has freeze protection. To be honest though the pump will last longer if you remove it before a hard freeze and then put it back on the pool when the snow starts to melt in early spring.
    It will freeze, less than a foot thick typically though.
    I would bring your pools pump inside for the winter and store it in a closet or somewhere not damp that won't go below freezing.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
