Thread: Solar Cover "Alerternates"
    Jul 2012
    Basking Ridge, NJ
    46
    OK, so just for some background, we have a 30k gal free-form pool with attached spa (I haven't been 'allowed' to put up pics yet; the wife won't let me until it's 'perfect'). There is obviously no standard solar reel that will fit this thing so after a little research, I found two alternates. One is this 'Swimming Pool Solar Pill' that you put in a skimmer and then claims to "Prevent pool water evaporation and heat loss with an invisible layer of non-toxic biodegradable film". The other are these 'Solar Sun Rings' which, as far as I can tell are just small circular inflatable pieces of regular solar cover material.
    I'd love to know if anyone has had experience with either of these products and what their feelings about them are and also what might be the best way to cover the pool, traditional reel, alternative or otherwise.
    Looking forward to your replies!!
    - Patrick
    28,000 Gal Pool w/ Attached raised Spa, White Plaster Finish, D.E. Filter - FNSP 60 sq. ft., Whisperflo Pump, Nature 2 Element (Housing Only Now Devoid of Cart.), Hayward CL200 In-Line Automatic Pool Chemical Feeder, RayPak Gas-fired Heater, Polaris 380, Zodiac 1.5-HP 240-Volt Polaris QT Spa Blower
    Jul 2010
    Philly
    332
    Re: Solar Cover "Alerternates"
    I have those solar rings. I've also tried the those solar pills. The solar pills in my opinion are not worth the money. They work, but in breezy conditions the film just gets blown down wind and hugs the wall. It fails when it's most needed. Better then nothing but I would not buy again.
    Right now I'm using solar rings. I find them a decent substitute for a real solar cover. So far they've held up pretty good for two seasons. Downside is they don't completely cover the pool and don't stay put in stiff breezes and will flop over on themselves occasionally. In storm winds they will blow out of the pool. I would rate them much better than nothing.
    In a pool your size, that's a lot of rings. They're not cheap and though not as cumbersome as a real solar cover they do take time to place in or remove from the pool. More tedious than difficult. Since they're round, figure on them covering about 70% of your pool. When mine bite the dust, I'm going back to a regular solar cover because I want 100% coverage. The rings were a concession to family members who hate wrestling with a full solar cover.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    May 2012
    Montville NJ
    545
    Not sure if it helps, but when i was a kid my neighbor had a free form kidney shaped pool.
    Any solar cover he bought would have had to been odd shaped and had a lot of waste.
    His wife worked in the shipping department of some company and "acquired" a large roll of "Bubble wrap" and he made his own cover that consisted of 3 or 4 seperate peices. I remember helping to put it on and take it off as a kid. It was pretty easy to do.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    I have seen posts where users with similar pools bought a cover to fit the pools length x maximum width. Pull it straight out across the length of the pool and trim to fit. Once that is done, using it with a standard solar reel of proper width should be a piece of cake.
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
