Thread: Bottom drain and running pump
    Mar 2009
    Woods of North Florida
    148
    i think I have a leak in my pool. I have a bottom drain. Can I close the skimmer valve and run the pump using only the bottom drain while I watch the water fall to find the leak?
    Thanks as always for help!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    30,431
    Re: Bottom drain and running pump
    I don't see a problem with using the main drain only instead of both skimmer and main drain. Perhaps the only issue will be some loss of psi on the gauge and the slight possibility of air being sucked into the system because of the suction side restriction. Nevertheless, there is no harm.
