Thread: Help with Balancing - Again...
    Hi everyone...
    I've been balancing through pool calculator for the past month and everything's been generally fine...no algae or cloudiness, but the water seems a bit harsh and I can't tell if I'm doing something wrong or missing something:
    Here are my numbers via Taylor 2006 Test:
    FC= 1.8 (I know this is low, and I need to shock up)
    CC= 0
    PH= 8.0 (I know this is high, need to add Muriatic Acid)
    TA= 100
    CH= 100
    CYA= 60
    So here's my question: I haven't added any borax to the pool since I first started using BBB method. Clearly my Ph has remained high...And I've never added any baking soda either. It seems like my numbers have always been in the ballpark, and the only daily dumps are bleach...and that's it.
    I assume this is ok?
    One thing about pool calculator that I can't figure out is the borate section. How do I even test for Borate? Isn't that the same thing as the PH test?
    Thanks for your help!
    L.
    21,000 Gallons; Filter: Hayward DE 4820 Filter; In Ground Pool; Vinyl Liner; Hayward Super Pump...Don't know flow rate; Approx. 5 years old (by previous owners), New Jersey
    Apr 2012
    SW Ohio
    456
    Re: Help with Balancing - Again...
    You test borates with test strips I bought mine from tftestkits.net I try to keep my ph around 7.4 and anytime it gets to 7.8 I lower it back down to around 7.3 or so......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by number419
    Hi everyone...
    Yes, it is low! With your CYA of 60, FC should be maintained between 5 & 9 and never below 5.
    CC= 0
    Each time the pH hits 7.8, lower it back to about 7.4.
    TA= 100
    CH= 100
    CYA= 60
    You #'s, CYA, CH & TA are fine as long as you maintain the FC & pH!
    You would use borate test strips, but if you have not added borates, you have no need to test for them.
    Isn't that the same thing as the PH test? Nope. Not at all. You can read about borates in Pool School.
    L.
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Harsh is probably the pH. Soften it up with Muriatic acid. And get that FC up, or your next thread will be about your green pool.
    Ok, thanks for all you help!
    I guess other than letting the FC get so low, I'm doing everything else fine. I'll shock it tomorrow...
    I'll read up about borates so I can better understand it...
    Thanks again!
    Smykowski's Avatar
    Sep 2011
    3,065
    Let's make sure you're using terminology correctly... No need to "shock," which is the process required to clear a dirty pool. All you're doing is adding a maintenance dose of chlorine to get back into your normal range. (BTW, you should be adding a maintenance dose every 1-2 days, and never ever let that FC number get below 5)
