Results 1 to 11 of 11
Thread: Please help - pool is a green mess!
    We have an above ground pool, approx. 14,000 gal with an SWG. All was well until about a week and a half ago. We had about 50 hours of rain with hurricane Isaac. Also, the bearings went out on our pump. Now it is a green mess. We have been putting in muratic acid since yesterday to get the ph down so we can shock but it hasn't budged much. Changed the pump out today. Also added CYA yesterday but know that takes a while to show up. Here are our test results:
    Ph 8.2
    CL 0
    CYA 0
    TA 110
    Salt 2100
    Feeling a little overwhelmed - can anyone help?
    Courtney
    Re: Please help - pool is a green mess!
    Make sure you are not using "safety" Muratic Acid. It takes alot more of that to get the same results. Don' ask how I know that.. Get some good stuff from the pool store - or ???
    I bought my MA from Walmart - it was the the "safety" kind.
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Thanks - It is the stuff from the pool store.
    Oct 2011
    New Caney, Texas
    414
    You can get it at most Hardware stores and Home Depot
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Yes, get the pH under control first. Have you found the PoolCalculator.com to help with the doses?
    What size/gallons is the pool? We can help you calculate/verify the dose if you would like.
    You're done SLAMing when:
    Yes - I did use the pool calculator. Great tool! Does it usually take a while to bring the ph down? The pool is a little over 14,000 gallons.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by court475
    Actually, it should only take a little while unless the pH is actually higher than 8.2. You should be able to calc a dose to drop from 8.2 to about 7.5, add the muriatic adic, circulate, retest in an hour and should be on/near target.
    Are you adding the TA to the calculator?
    Regardless, keep adding/testing until you reach your pH target.
    Well it could have been higher than that to start. It was at least 8.4 last night. Then 8.2 tonight. We were gone all day so didn't get to work on it but added some more when I got home. Will check again.
    Ok - just checked and the ph is way down! Last question for the night - should I throw some chlorine in there now or just wait until tomorrow evening when I can continuously add and test?
    Butterfly's Avatar
    South Carolina
    10,045
    I suggest you wait until the pH is under control and then start the shock process as outlined in Pool School.
    ETA: If "way down" means that the pH is in the low 7's, then I'd start the shock process tonight!
    Thanks!
