Thread: How to figure out cyanuric acid without test kit??
    Arusha, Tanzania
    9
    I live in Africa with limited pool resources. I can buy stabilizer but I have no way to test for cyanuric acid. In a few months I can get a test kit from the USA but I need to know how much stabilizer to add today. Attached is the well water I used to fill the pool. Since then I have added acid and chlorine and gotten the pH and alkalinity in the normal ranges. Is there any chance well water has cyanuric acid in it or can I assume it has zero in it? If zero, then I would add the appropriate amount of stabilizer today and then start testing later. What do you think?
    Thank you for your help.
    Best,
    Patrick
    26,000 gallons
    sand filter
    IG
    plaster -- poolcrete
    June 2012
    30,432
    Re: How to figure out cyanuric acid without test kit??
    CYA doesn't occur naturally. Since you started with zero, simply calculate the dose and assume it's there.
    22,553
    What type chlorine have you added?
