Thread: How often do you "scrub" the walls of a Fiberglass pool ??
    Jun 2012
    Lafayette, Ca / USA
    260
    We have an older Fiberglass pool ... There is definitely a slight build-up of some dirt or something (calcium??) (it's not algae) - I rub it with my finger and it does come off. What kind of general scrubbing maintenance should be done, how often, and what would I use ?? It has not been done all summer.
    Thanks
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: How often do you "scrub" the walls of a Fiberglass pool
    People typically brush once a week. It doesn't seem to matter what surface.
    I recommend a wall whale. It has nylon brushes and the fin applies the downward pressure. All you do is push it back and forth. It saves a lot of back, shoulder, and arm aches.
    Jun 2012
    Lafayette, Ca / USA
    260
    Thank you .. me bad -- more research in Pool School revealed this to me ... I'm looking into the Whale Tail on Amazon as we write.
    Jan 2012
    'burbs of Augusta, Georgia
    7,296
    I try to brush at least once a week with my wall whale just because I understand the importance even if I've never really seen a difference in the pool other than never having had algae.
    I also have this big textured blue glove that I use to scrub the scum line with. Its nylon loop fabric (a bit like velcro?) and its handy because I can just swim along the sides and scrub away which is far more fun than using a brush from outside the pool.
    I purchased it at a pool store and I don't know the brand name. I need another.
    Jul 2011
    Mesa Arizona
    190
    Wow. I wish I could only brush once a week. It's dusty here in the desert so my pool gets a brown haze on the bottom every couple of days. I sweep about 3 to 4 times per week. We also get dust storms occasionally. That sucks but it's actually kind of interesting watching your pool turn brown in minutes right before your eyes.
    I'm picky though. I see a little discoloration on my plaster pool and I'm brushing the entire pool. I can't remember the last time I didn't brush for 3 days in a row. I'm guessing last March.
    The dust around here is one of the few drawbacks to living in the desert.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Figured I would bump this rather than make a new thread. Any other brushes that people have used besides the Wall Whale? Just want to see what options are out there.
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
