Thread: Pre-Build Checklist :?
    cityartist's Avatar
    Sep 2012
    Burbank, California, United States
    8
    I'm just getting quotes in, as I prep for the possible build, and the best one seems good, but I'm concerned I may be missing something that I need, or otherwise am not processing the info correctly. I'd be thrilled with some sage advice, before I make a big mistake!:
    Elements covered in quote:
    Shallow Depth - 4'
    Deep End - 7'
    Permit/Zone Charges included
    Supervised Construction
    No SWG included (but I'm thinking I should gt one. Thoughts? Is it well worth it? What would be a reasonable price to add that?)
    Filter - Pentair, whisper Flow pump and motor, 420' Clean and Clear Cartridge Filter, and in-ground skimmer
    Coping - Poured in place concrete, bullnosed on RBB, and pool edge. Otherwise 2' poured concrete additional decking all around
    All taxes inc.
    Excavation and dirt removal
    6" band of waterline tile
    medium marbleized waterproof plaster (colored)
    Electrical run from panel to eq./pool light w/ GFCI Safety breaker
    500 Watt incandescent marine light
    2 child safe double suction drains w/ 2.5" pipe ("Sewer line" is not mentioned. Should it be?)
    15' skimmer run
    Three 2.5" return lines of 40'
    Autofill
    Solar Heating (PB believes that since I'm not getting a spa, and pool is relatively small, this would be ample in SoCal weather for year-round swimming, and save me a lot of money)
    2 Sheer Descents
    18" raised bond beam in back corner
    16" reef at top step
    Stacked Stone on RBB
    6' Stucco Block Wall 10' long
    Stacked stone on wall up to 3"
    Sod removal
    I'm getting an estimate of about $37K. However, I'm most concerned about equipment , parameters, etc. I realize price changes all over the country!
    Thank you in advance for any feedback and advice you can offer, as I dive in to this new experience!
    Newbie, just beginning to get the right pool configuration! Plan is for 16,600 gallons, Cartridge filter, IG, medium plaster.
    Nov 2012
    Los Angeles, CA
    11
    Re: Pre-Build Checklist :?
    What's the width and length of new pool?
    Melbi Stylz
    Beach Entry, pebble sheen, natural rock waterfall, raised bondbeam w/ 2 3ft cascades, Pentair VS Pump, 1hp Pentair whisperflo main pump, 1hp booster pump, FNS 60Sq Filter, Jandy Aqualink RS6, Sta-Rite Master Temp 400,000BTU, Raised Spa, Breeze salt system
    cityartist's Avatar
    Sep 2012
    8
    UPDATE: This Build is now almost completed.
    38,235
    Quote Originally Posted by cityartist
    Then do you already have one of the recommended test kits on hand to be prepared when the pool is full?
    Nov 2012
    Los Angeles, CA
    11
    I paid $1,500 for Salt water generator. with a 5year warranty on cells.
    Melbi Stylz
