Results 1 to 7 of 7
Thread: Water Flow / Pump too fast?
    Ive been reading the pool school, bought the recommended test kit and understand the test kit, and finally replaced all of my orings and have perfect suction and I'm 99 % i have no suction leaks. My problem now is that I cant get my filter to filter - now that my pump seems to be running better than ever, its working too good i guess.
    It seems like the water is shooting in and out and bypassing the catridge filter. I'll let the air bleed out and 5 minutes later go bleed it out again and again, etc. Its like the water is going out faster than it comes in if that makes any sense. If i look at my jets, i see the algae i'm vacuuming up shooting right out instantly. I did have to buy a new pool motor and i bought one at Leslies - one of the Ecotech variable speed motors 3.5 hp at 100 %. Maybe its too powerful?
    TEST KIT: Taylor Technologies K-2006C
    POOL: 33,000 gal 20'x40' IGP, Vinyl, 1.5 HP Two Stage Pump Motor, 340 sq.ft. Jandy CL340 Cartridge Filter, Jandy Aqua Pure PLC1400 SWG, Polaris 280, AquaLink RS By Jandy Control Center with Jandy PDA Model #8265
    JACUZZI: 320 gal Caldera Spa Paradise Series Martinique with OEM Aqua Sun Zone - XL-30AE Ozonator
    38,237
    Re: Water Flow / Pump too fast?
    what size of the filter? It would have to be huge to use that pump any where closer to full speed.
    What happens when you turn the speed down ?
    Posted from my Droid with Tapatalk ... sorry if my response is short
    30,401
    If air is getting in to your system, you haven't solved the suction side air leaks. That's the only source for air.
    hmm i guess - i'll be checking around for more leaks. It has to be it - could an air leak in my filter housing cause an issue or is it always before the impeller?
    30,401
    Always before the impeller. Air cannot be drawn in on the pressure side.
    A water leak (pump running) is pressure side and air in the system is a suction side leak.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by ke263565
    So what speed are you running? Too high and it can damage the filter not to mention drawing in air on the suction side.
    Mark
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    I am a fairly new pool owner - with an older pool. When I took over the pool there was no one to explain anything. My pump basket always had a little air in it until yesterday. Both suction side valves were partially closed, and when I opened them both, the air magically
    was gone.
    The point if this is that tiny suction leaks can exist and lowering the pressure relative to the supply helps. Maybe turning down the pump speed will eliminate the problem - should be an easy test.
    -sent with Tapatalk 2
