Results 1 to 13 of 13
Thread: Winterizing Intex Ultra Frame questions
    From all the reading i have done i have not come up with a solution on how to properly winterize my 18'x48" Intex. I've read some people don't drain water and just plug the holes, some drain water below lowest hole. And with covers i know i can't use a conventional since the frame can't support it. I live in Pittsburgh so we can have really nasty winters and then on occasion we have mild winters like last year. If i drain the water to half way and don't use a cover or pillow would that be good enough? Next year i will be draining all the water to fix a few legs and move some pavers so i am not really concerned what kind of condition the water is in, and i also have no trees anywhere near me to worry about leaves or other debris. Would the water freezing cause any damage to the liner or frame since i won't have a pillow? Could i use a pillow with no cover and just anchor it down somehow to give the ice somewhere to expand? My pool is a salt pool, i am assuming that once the temps get into the teens that the water would still freeze. I also have the sand filter, how do i properly winterize that? Is it just as simple as drain the water from it, take the valve into the house and cover the top with a bag?
    Currently a big sand box with no pool, 18"x54 on order
    Hayward EC40 filter with Hayward 1HP pump, Wanda the Whale
    SWG
    Apr 2012
    SW Ohio
    456
    Re: Winterizing Intex Ultra Frame questions
    i have a 18x52 intex ultra frame pool and i am following the closing your above ground pool article in pool school for mine i have the same sand filter as you and mine is hard plumbed but i plumbed it to where i can take it all apart and store it in the heated garage, i went to harbor freight tools and bought one of those little 4 wheel dollies and will set the sand filter on it and roll it into the garage but thats after i drain the water out of it, i'm old.....lol..........Mike
    i'm from Ohio ....Howdy Neighbor......lol
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    What size cover are you using? I was thinking if i got one big enough that fit inside of the pool and still hang over the sides and just let it fill up with water. Unfortunately with the landscaping of my yard and where the filter is, moving a 100 pound sand filter full isn't an option. I might just empty the sand out of it and take the tank inside
    SWG
    Jun 2012
    MA
    347
    If you are not trying to save the water anfd you are going to drain it in the spring , then why not take down the pool for the winter. Some times trying to avoid work ends up being more work.
    My dog would have a field day digging in her new sand box
    SWG
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,389
    Keep a cheap tarp over it? (The sand, I mean.)
    i thought of covering the sand but once the dog realizes there is digable ground under it the tarp wouldn't stand a chance of survival. And I don't really have a place to store the pool, garage isn't heated.
    SWG
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,389
    I stored our easy set in an unseated garage, and will likely do the same with my ultra frame. I always make sure it is completely dry before I roll it up.
    Jun 2012
    MA
    347
    I store my pool in a clam shell cargo carrier. I say let the dog dig, just rake it next year. Leaving a pool up reduces the lifetime of the pool. The sun will fade and break down the liner. The poles will move around and wear at the junctions and rust.
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    I'm in favor of taking it down. I store mine in an unheated shed. I think tear-down and set-up are easier than cleaning in the spring.
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    SE Minnesota
    91
    as far as the sand filter, just unplug it to drain the water, cover the valves on top with a plastic bag and leave it. No need to remove the sand or move the filter inside.
    Mona SE MN
    24' round 48" high AG
    Meteor Sand Filter
    1.5 HP pump
    Aug 2011
    Augusta, Kansas
    88
    We're taking down our rectangle Intex pool this year (several polls have sunk and it's just easier to drain and redo).
    Anyway...we bought some of the orange snow fence and t-posts. The snow fence is pretty cheap on eBay.
    My hope is that this barrier will keep the dogs away (our pool is in line with the charge from one end of the yard to the other - between the digging and the races we'd lose a lot).
    Diane
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    I live in NJ and this is the second year we've had our 18' x 48" Intex pool. I have a winter cover we purchased from In the Swim. We also have a solar cover which I left under the winter cover. I left two rafts tied together in the center in the pool for a pillow. Our winter cover goes over the side about 12'' to 15'' down the side. I do have to periodically go out through the winter and pull it down in different areas as it pulls up. I saved quite a few windshield washer fluid bottles that I may add water to and hang from the cover with bungy cords to keep the cover down this winter. My brother-in-law does that with his pool but he has a regular agp. We shall see how it works for me. I also have a Intex SWF and a Intex Sand filter. This is the first year I am winterizing the sand filter which is why I am on here tonight.
